Old 2016.05.16, 10:25 AM   #1
helee4
helee4's Avatar
Send a message via MSN to helee4 Send a message via Yahoo to helee4 Send a message via Skype™ to helee4
Clone pcb
I am wondering if anyone has experience with the clone asf board. Saw couple of them being sold in eBay for about $50.
helee4 is offline   Reply With Quote
Old 2016.05.16, 08:11 PM   #2
byebye
byebye's Avatar
I know there were a couple posts about them but I too am wondering.
Kris
Old 2016.05.16, 09:36 PM   #3
lfisminiz
lfisminiz's Avatar
So far Al has one and so far its good. (ASF board).
Old 2016.05.17, 10:27 AM   #4
helee4
helee4's Avatar
that's good to know there are cheaper option out there in case of our board is blown..
Old 2016.05.17, 11:16 AM   #5
refsiul22
refsiul22's Avatar
brushed or brushless?
Old 2016.05.17, 11:37 AM   #6
helee4
helee4's Avatar
looking at one for brushed/MR03 by DasMikro
Old 2016.05.17, 11:53 AM   #7
lfisminiz
lfisminiz's Avatar
Brushed board.
Old 2016.09.09, 11:14 AM   #8
refsiul22
refsiul22's Avatar
Has anyone else experienced with this board? Any Pros & Cons?
Old 2016.11.02, 07:43 PM   #9
rojak
rojak's Avatar
Bought 2 pcs, one for mr03 the other one for awd.
MR03 working fine, can bind with my ex-5ur or kt18 same with AWD board too.
Throttle both board same, can be adjust via ics, only difference with steering response, AWD board i need to adjust the speed to lowest speed since it is hard to control.
By the way, both board I install on MR015 and MR02 body.
MR01->MA-020VE->MR02-VE>MB010
rojak is offline   Reply With Quote
Old 2016.11.03, 08:01 AM   #10
helee4
helee4's Avatar
Just also just swapped out all the wiring/servo motor from an old Kyosho ASF MR03 board to the Dasmikro clone. Haven't really track tested the car with the cloned board, but at least I felt the steering/throttle response seems similar to the OEM board
Old 2016.11.03, 10:36 AM   #11
refsiul22
refsiul22's Avatar
out of stock
Wanted to try it, but it is out of stock in Banggood. Do you know where can I find one? (apart from e-bay or amazn)
Old 2016.11.03, 11:14 AM   #12
helee4
helee4's Avatar
We bought it from ebay. It was pricier than in Banggood, but unfortunately they are out of stock..
Old 2017.10.11, 07:57 PM   #13
SuperFly
bitPimp
SuperFly's Avatar
Question about the steering servo
I'm interested in dropping the dasMikro ASF MR03 clone board into an MR02 chassis. Does anyone know if I can just add the third wire to the pot and use the MR02 steering motor? If I have to use an MR03 servo motor, do I just have to figure out how to secure it in the chassis? Anyone done this before?
mini-z gallery
PDX Mini-Z
Old 2017.10.11, 10:23 PM   #14
cowboysir
adding the wire works fine and the 02 motor just needs to reverse polarity compared to the 03 servo motor.
my custom body album...
Old 2017.10.17, 08:04 PM   #15
anyone have a wiring diagram to show where the switch/power wires go? for the servo and pot, is it a direct swap over in same order? FYI, i'm swapping out an MR-03 sport series 1 PCB for the clone ASF.
FS- (1)mr-01 pcb & (1) F1 pcb bobbyz Mini-Z Marketplace 2 2009.08.13 01:55 PM
FS: Overland/Monster PCB AND WTB: MR-015 Parts MINIz guy11 Mini-Z Marketplace 8 2009.01.14 08:47 AM
PCB problems (steering) michvin Parts and Hop-ups 14 2005.12.02 10:00 AM
Iwaver PCB vs. Mini z PCB Dustin Miscellaneous Discussion 2 2005.03.14 12:00 AM
New Iwaver PCB and Chassis Set Jackd iWaver 30 2004.11.22 11:29 AM
