Old 2015.11.30, 04:15 PM   #1
Thorvald
Thorvald's Avatar
3D Printed MR-03 Motor Wire Clamp
Well got sick of the wires fraying and breaking on the PCB of our MR-03s so I made up a simple clamp that bolts to one of the rear top deck screw holes.
Now the wires at the board side cannot flex during suspension travel etc.
http://www.thingiverse.com/thing:1162721
Cheers
Tim
Old 2015.11.30, 06:21 PM   #2
very thoughtful. have any tricks for bundling up the rear end wires and plugs?
Old 2015.11.30, 07:17 PM   #3
cool idea...
Old 2015.11.30, 08:14 PM   #4
Thorvald
Thorvald's Avatar
I was considering a new rear motor bracket for the MM chassis that incorporated zip tie holders ... but still need to see if ABS printed can handle the stress (I doubt it).
Right now this is how I do it with the clamp:
1. Zip tie around rear motor mount/clip and then another zip tie around the "bouncing bundle" in the middle.
Still not 100% satisfied with this... so might so something custom with the rear pod shock mount that add's a zip tie slot sticking out to the left (Drivers side).
Next project lol.
--- And then once I move to a fancy PN rear end with damper etc, I'll have to make a difference design as I think that hole is used.
Old 2015.12.25, 12:46 PM   #5
KWT
How about putting a loop for a zip tie on the wire clamp? Lately, I've been putting the motor wires parallel to the shock and over the battery clips. It gets all the wires mostly out of the way.
Printed bodies Fovea3d Zcuderia bodies 384 2018.05.07 02:48 AM
3D Printed Prototype byebye 1/28 Scale Chassis Discussion 25 2015.03.29 02:30 PM
KO Propo EX-10 Eurus / Helios Antenna Shields - 3D Printed ModManKev KO PROPO 1 2014.01.04 10:13 AM
Mini-Z MR03 High Clamp Force T-Plate Mount PNracing PN Racing 9 2010.01.13 01:01 PM
PN Racing MR015/02 High Clamp Force T-Bar Mount crazyracer PN Racing 11 2009.02.06 01:14 AM
