Old 2009.04.21, 01:53 AM   #31
ub0211042
ub0211042's Avatar
Hi LED,
I did put in the batteries and switch it on while pressing the pairing button, the LED lights up but when i connect to PC nothing happen.
I got the the ASF manager and assign Comm port 6 (which i plug into) and click "Read" and i try to change some settings and click "program" then i quit the application then run it again. when i click "Read", it only show the default setting.
i've check with multimeter and theres no loose connection between all wires and connection. check using voltmeter and theres around 3v at the red and black wire.
btw, hv u build this ICS cable before?
Mini-Z AWD 2.4Ghz 94mm
Mini-Z MR-02 2.4Ghz
Mini-Z MR-03
FX-101 Dnano 360 Modena
Old 2009.04.21, 04:05 PM   #32
LED
I havent build one myself.
I dont know enough about electronics to answer what could be wrong.
Be sure to use the laters software.
Maybe PM dabinn to ask for some things you could test out to find out if a component is broken.
Did you try other comm ports in the program ?
Old 2009.04.21, 09:41 PM   #33
dabinn
Originally Posted by ub0211042 View Post
Hi LED,
Use a PC with a serial port to test at first. Avoid the problem of USB to RS232 converter.
And make sure the pin assignment of the transistors are correct. Most of them are not the same with my drawing.
A MINI-Z fan from Taiwan.
http://mini.zclub.com.tw
dabinn is offline   Reply With Quote
Old 2009.04.21, 11:27 PM   #34
ub0211042
ub0211042's Avatar
hi dabinn, how to know the pin assignment of the transistor using digital multimeter? i've search the net but none found ...it seems that only the diode and the transistor need to put in a correct position (pin assignment)right?
i have no pc with serial port, only USB...how can i resolve using USB? is it as easy as plug n play or i need to configure something else.
Thanks
Mini-Z MR-02 2.4Ghz
Mini-Z MR-03
Old 2009.04.22, 02:06 AM   #35
dabinn
Thanks
Yes, the diode and the transistor need to be put in right direction.
You may use a multimeter like mine, it have a transistor test function. It would be more easy to distinguish it's pins.
Acutualy no configuration is needed with the USB converter. All you have to do is installing the driver for it(if needed). But some of them may are not very compatible with all rs232 devices.
Since you don't have a serial port, You may try to diagnose the ciucuit at first, eseciailly the transistors.
Old 2009.04.22, 02:23 AM   #36
ub0211042
ub0211042's Avatar
thanks so much for ur reply, when i put the transistor into the digital multimeter, the multimeter should "beep" indicating its the right direction? or there will be some readings i need to obeserve.
and do u hv the link to download the ASF manager which is in english version? mine will only come out in weird character.
Mini-Z MR-02 2.4Ghz
Mini-Z MR-03
Old 2009.04.22, 10:02 AM   #37
LED
its on this page
http://www.kyosho.com/eng/support/in...racer-awd.html
But be sure to change the language to english on top of the page somewhere before download. Else you get the japanese version (what you have)
Old 2009.04.23, 12:17 PM   #38
ub0211042
ub0211042's Avatar
im so happy tonight....come in to office at 12 am just to use the old computer which still using serial port, the DIY ICS is working just fine...thanks so much Dabinn and LED!
Mini-Z MR-02 2.4Ghz
Mini-Z MR-03
Old 2009.04.24, 12:45 PM   #39
dabinn
Congratulations!
Old 2009.04.24, 01:11 PM   #40
ub0211042
ub0211042's Avatar
Originally Posted by dabinn View Post
Congratulations!
one more, how to use the USB-Serial converter?
mine only works if directly connected to serial port not the usb
Mini-Z MR-02 2.4Ghz
Mini-Z MR-03
Old 2009.04.24, 02:41 PM   #41
LED
Do you need software for the usb-serial connector ?
I guess you need to try every port untill you find the one that works.
Old 2009.04.24, 11:09 PM   #42
ub0211042
ub0211042's Avatar
it only needs a driver and ive already installed it, tried on all ports but still no luck...dabinn said some USB - Serial converter might not work, is it true?
Mini-Z MR-02 2.4Ghz
Mini-Z MR-03
Old 2009.04.25, 12:46 AM   #43
Skv012a
Skv012a's Avatar
Won't work for voltage regulation, but how the hell else would you connect it to PC? I think kyosho usb dongle simply regulates the voltage and is otherwise the same as this solution. I hope I'm not wrong, because being stuck w/ using series renders this marvel utterly useless.
Hey can I just wire 4x 10k Ohm resistors in a series to replace a 39k one? Radioshacks don't even carry those, but I have lots of 10k ones.
New site.
Old 2009.04.25, 12:20 PM   #44
LED
Yes you can put resistors in serie and add the values to eah other.
Ub02... did you download the manual on the same link I gave earlier ?
Read the bit about how to check wich com port you should use.
If that doesnt help then I suppose its the usb- serial convertor holding you back.
Old 2009.04.25, 02:25 PM   #45
totalazneclipse
Noob Extraordinaire
totalazneclipse's Avatar
Is there going to be a difference between the 39k and using 40k? Im in the same dilemma i don't really feel like using 3 10k's and more misc ones to make 39k.
-2x ASF MR-02
-ASF MA-010
All Speed Hobbies
totalazneclipse is offline   Reply With Quote
Hacking the ICS cable ianc 2.4GHz ASF System (Auto Selected Frequency) 28 2009.04.15 05:49 PM
resetting ICS without the cable, program? tosh 2.4GHz ASF System (Auto Selected Frequency) 2 2009.04.04 10:55 AM
Stupid I.C.S. questions... cowboysir Beginner Questions 2 2009.03.27 08:42 AM
