2013.05.29, 06:02 PM
pyschopath racing
Ccc#3 @ hsh
CCC #3 @ High Speed Hobbies
July 20th 2013
20 for 1st class
10 for 2nd class
10 for 3rd class
races will start at 10:30 am
will start driver list on next post
Grand Touring Classes
Chassis: Any 1/28th scale 2WD chassis.
Track Width: 80mm max
Wheel Base: 86-102mm
Body: Kyosho ASC, White Body or equivalent (TRP, Iwaver, X-Mod, etc...) hard plastic bodies allowed, excluding LM-LeMans Prototype bodies (See LMP class list) or Can-Am/Pan-type bodies. No thin shell Lexan/polycarbonate bodies allowed. Bodies may be altered for wheelbase but a maximum wheel opening of 31mm measured horizontally must be maintained. Wheel wells may be altered for tire clearance but the body must cover the tire completely when viewed from above. Cabin window must be retained but may be lightened internally, polycarbonate (Lexan) windows allowed. Headlight buckets may be removed but lenses or covers must be retained. Taillight lenses and housings may be removed. The rear fascia or bumper maybe cut but no higher than 18mm from the chassis bottom plane. Holes are legal in the remaining fascia. Small body parts such as mirrors, canards and exhaust pipes may be omitted. Front air-dams, splitters and body sides may be trimmed for track clearance.
Width: 82mm max.
Length: 200mm max
Height: 70mm max
Wing: All wings original to the body are legal. Aftermarket or non original wings must fit within the confines of main body. Wing must not extend higher than roof line relative to chassis bottom plane (excluding extensive roof scoops, for example Kyosho NSX), past widest point of body, or beyond rear of body work. This includes all parts of wing (side dams, etc...).
Electronics: Unlimited.
Batteries: 4 x AAA NiCad, NiMh or Alkaline (Lithium based batteries NOT allowed)
Wheels: Any Mini-Z type wheels, plastic or aluminum.
Front: 9 x 22mm max
Rear: 11 x 22mm max
Tires: Any rubber Mini-Z type tires (no foam).
GT2
Min Weight: 175g with transponder.
Motor: Spec motor designated by the Event
Le Mans Prototype Classes
Wheel Base: 102mm only
Body: Kyosho LM-LeMans Prototype ASC or White Body only:
Porsche 962, any version.
Mazda 787, any version.
Sauber C9, any version.
Wheel wells may be altered for tire clearance but the body must cover the tire completely when viewed from above. A maximum wheel opening of 32mm measured horizontally must be maintained. Cabin windows must be retained but may be lightened internally, polycarbonate (Lexan) windows allowed. Headlight buckets may be removed but lenses or covers must be retained. Taillight lenses and housings may be removed. The rear fascia maybe cut but no higher than 18mm from the chassis bottom plane. Holes are legal in the remaining fascia. Small body parts such as mirrors, canards and exhaust pipes may be omitted. Front air-dams, splitters and body sides may be trimmed for track clearance.
Width: 82mm max.
Length: 200mm max
Height: 60mm max
Wing: All wings original to the body are legal. Aftermarket or non-original wings must fit within confines of main body. Wing must not extend higher than roof line relative to chassis bottom plane (excluding extensive roof scoops, for example Kyosho NSX), past widest point of body, or beyond rear of body work. This includes all parts of wing (side dams, etc...).
Batteries: 4 x AAA NiMh or Alkaline (Lithium based batteries NOT allowed).
LMP1
Front: 9 x 22mm max
Rear: 11 x 22mm max
Tires: Any rubber tires (no foam).
Min Weight: None.
Motor: Any 130 size brushed motor. Brushless not allowed
F1
Chassis: Kyosho Mini-Z F1 chassis only!
Track Width: 85mm max
Wheel Base: 130mm only
Body: Kyosho Mini-Z body (ASC or prepared white body) only!
Width: 85mm max.
Length: 210mm max
Height: 50mm max
Wing: No wider than 58mm. Mounted no higher than 45mm.
Min Weight: None.
Wheels: Any Mini-Z Formula 1 type wheels, plastic or aluminum.
Tires: Any Mini-Z Formula 1 rubber or tires.
Batteries: 4aaa NiMh only.
Motor: Any 130 size motor
2013.05.29, 06:11 PM
pyschopath racing
Drivers list
GT70
Albert
Micheal H.
Drake
Chad
Andy
Marwan
Scott
Don
Brandon
Eddie
Bryan
Landon
LM1
Albert
Micheal H.
Drake
Chad
Andy
Marwan
Scott
Don
Brandon
Eddie
Bryan
F1
Albert
Micheal H.
Drake
Chad
Andy
Don
Brandon
Bryan
2013.05.29, 08:03 PM
All 3 for me
PN Racing
R1Wurks
LET's Go Racing
DG Designs
2013.05.29, 08:12 PM
cc3
drake and i for all 3
MiChAeL
2013.05.29, 09:49 PM
Scott
GT and LM for me
Scott
2013.05.30, 07:12 AM
of both Time and Space
GT2 and LMP1 for me too!
2013.05.30, 07:20 AM
All three for me.
Andy
LET'sGo Racing
2013.06.10, 07:24 AM
you can put me for all 3...not 100% sure i'm going to make it..i have a car meet a couple of weeks prior
2013.06.12, 07:03 PM
ccc3
Hey Albert put me down for gt70 and lmopen trying like crazy to get it scheduled to be there!
2013.06.22, 10:59 AM
Put me in for all 3
2013.06.22, 01:45 PM
pyschopath racing
who else is racing in CCC#3
2013.06.22, 08:41 PM
MiChAeL
2013.06.22, 10:14 PM
Landon's not even on the list. What's up with that
PN Racing
R1Wurks
LET's Go Racing
DG Designs
2013.06.22, 10:33 PM
Been working too hard to play on the net Chad. I'm in for two classes at least, GT 2 and something
Landon
LET's Go Racing!
2013.06.23, 07:59 PM
all work and no play some people dont no what that is lol just joking guys
MiChAeL
