Old 2002.01.17, 03:19 AM   #1
Talking puegeot headlight solution
here's my peugeot headlight solution....
no matter how much plastic i removed on the headlights (using a dremmel to remove the excess plastic on the headlights), it always seemed to get in the way of the front wheels so i just decided to take it all out
i got a piece of material that would approximate the looks of the headlight from some sort of bag of chips (i.e. doritos, leys)... cut out a piece that was near to the ripple at the top (in the picture, its right next to the scissors) and stuck it in place of the original headlight with masking tape...
http://mini-zracer.com/forums/attach...s=&postid=6865
and here's it finished... which one is the original?
http://mini-zracer.com/forums/attach...s=&postid=6866
kinda looks good, plus the wheels/tires don't rub anything anymore
oh yeah extra link.... coolest collection of miniz's i've ever seen...
http://www.geocities.co.jp/Playtown-...9/page030.html
thanks to funkydog...
Old 2002.01.18, 02:51 AM   #2
GHOST
GHOST's Avatar
Excellent work.
I love the looks of this body. Could you post a pic of your chassis set up.
Not sure if my motor mount will wor with this.
Thanks
SPEED COSTS!!HOW FAST DO YOU WANNA GO?
GHOST is offline   Reply With Quote
Old 2002.01.18, 06:34 AM   #3
Mondo
Mini-Zedologist - Fear me
Mondo's Avatar
Pugz 206
GHOST,
here's al link to a race ready 206:
http://mini-zracer.com/forums/showth...=&threadid=873
This should help.
Mondo
__________
Old 2002.01.18, 08:56 AM   #4
Russ
Super Moderator
Russ's Avatar
I did almost the same thing....I just took off the silver backing, and painted the clear lenses silver on the back side. Looks fine, can't really tell the difference, especially when the car's moving
Russ
Old 2002.01.18, 09:36 AM   #5
Wedginator
that's a really good way of preventing rubbing.... i think i'll try that, cuz my S2000 has the same problem.... but the wheel touches the lights when the suspension goes down...
Old 2002.01.18, 08:15 PM   #6
ghost...
here is a picture of my setup... using the peugot will require the kyosho high motor mount setting... and will take a while for you to get used to driving.... i put some lead weights taken from the tamiya mini4wd and stuck some under the motor mount to lower the cg in the back and put some weight up in front to balance it off (more or less)
you can also add a kyosho rear shock in the back by turning the whole assembly around... like what i did to my vitz...
Old 2002.01.18, 08:19 PM   #7
this is the rear shock on my vitz... kyosho just came out with a rear shock for the high mount... still not available here... so in the meantime this will have to do...
Old 2002.01.18, 08:25 PM   #8
if you can't solve it by using the dremmel, try putting in hard front springs, that way they won't compress as much, and you hopefully won't have any rubbing against the headlight assembly
Old 2002.01.18, 08:37 PM   #9
and here's a pic of my peugot and lancer...
Old 2002.01.18, 09:20 PM   #10
Wedginator
yea, i already use hard springs on my car.... well, i just have to try that method you mentioned and find out...
Old 2002.01.19, 06:55 AM   #11
Mondo
Mondo's Avatar
Beyond srings
Herman,
The 206's rub-a-dub-dub problem goes beyong springs.
A full-lock turn either way will have the tyres rubbing on the inner headlight moulds.
Obviously, this can be dialled out using the steering response setting on thr TX. I just thought I'd add that
I am still to make the mods, I have got the headlights out and I've also ground away the posts that held the inner headlight moulds. Do I follow your lead, or just paint the headlights silver, like Russ did?
Decisions...decisions.......
Mondo
__________
Old 2002.01.19, 08:17 AM   #12
Russ
Super Moderator
Russ's Avatar
Mabye this will make it a little easier to decide
Russ
Old 2002.01.19, 10:09 AM   #13
Mondo
Mondo's Avatar
Thanks
Thanks Russ,
Actually, it doesn't look to bad at all. Kind of reminds me of a polycarb/Lexan bodyshell
Once finishing this posting, I will continue to finish the headlights on the akward Puggy 206 WRC
Mondo
__________
Edit
Spelling mistakes and 1/one/uno typo
Old 2002.01.21, 01:31 AM   #14
killer
hehehe!..
killer's Avatar
Sir hernan! it's me! cool site! thanks man!
killer is offline   Reply With Quote
Old 2002.01.21, 05:42 PM   #15
Mondo
Mondo's Avatar
PUggy 206
Herman & Russ,
Examining the pictures of your lovely yellow 206's, I decided to get one for myself too..
YUp, there's something about that colour yellow that catches my eye.
Also, the metallic paint on my blue one will get scarred when I race it..
Now to try and hunt down some Tamiya 206 WRC warterslides...
Any idea where? I sure don't want to buy a Tamiya kit just for decals...
Mondo
__________
Headlight Install C_Rus Beginner Questions 10 2007.05.21 09:15 AM
Mini-ZRacer.com Parts Color Vote mini-z Parts and Hop-ups 110 2006.10.19 03:39 PM
Stock Motor Clip Temp Solution Se_12alty Parts and Hop-ups 4 2004.08.24 05:23 PM
What do you use to drill bodyhole for headlight setup??? matrix Parts and Hop-ups 3 2004.06.30 05:24 PM
Best Charging solution mcharles13 Beginner Questions 18 2003.06.02 11:29 AM
