Old 2010.11.03, 06:42 PM   #1
PNracing
Send a message via AIM to PNracing Send a message via Yahoo to PNracing Send a message via Skype™ to PNracing
Low grip RCP track reason!
Finally we find the one of the reason why the RCP track low grip, the answer is if you have run silicon tire in RCP track, the silicon material will stick on the RCP track make it less grip, that's why Kenon home track, Chad home track and some track they never run silicon tire in RCP track, so we a ton of grip in this year regional lay out as 7.2 at Mod, 7.7 at stock.
http://www.pnracing.com
http://PNWC.pnracing com
DownloadPNICS ICS Android Apps for ICS Setting
PNracing is offline   Reply With Quote
Old 2010.11.03, 07:05 PM   #2
Many manufacturers do not list the silicone content in their tires, so it is hard for us to determine what tires have silicone and what do not. I primarily use Kyosho tires... although, I think that even they have silicone.
Is there a way to test the silicone content in a tire?
Old 2010.11.03, 07:27 PM   #3
PNracing
All PN Carpet Tire is silicon tire, all PN RCP tire is rubber tire, Kyosho all tire is rubber tire, except they release 10 degree before is silicon tire, other brand I'm not sure.
Old 2010.11.03, 08:32 PM   #4
I had heard that the Kyosho MT tire were silicone...
From what I understand, most ATM tires have silicone (higher number have less silicone), but the new 8d rears do not.
Old 2010.11.03, 10:33 PM   #5
interesting discovery...
why do they put silicone in tires in the first place?
Old 2010.11.03, 11:14 PM   #6
Silicone grips better on carpet... and could be cheaper
Old 2010.11.04, 03:07 AM   #7
ah... is there a way to "wash" out the silicone off the rcp track?
Old 2010.11.04, 04:50 AM   #8
Not without chemicals, probably... the silicone is somewhat oily, so you'd probably have to chemically treat the track to get it out, which would probably completely kill the RCP surface. You could always scrub off the top and have everything resurfaced, but that's not exactly easy or cheap either.
That said, even with the grip advantage at Kenon, Chad's 7.7 in 70t stock was just ridiculous. Sure that's not a 69t motor, dude?
Old 2010.11.04, 06:30 AM   #9
being oily, would good ole fashioned soap and warm water do the trick?
Old 2010.11.04, 08:32 AM   #10
Action B
The Galliant Dude
A little dish detergent gets oil spots out of my clothes. Seems like it might work.
Action B is offline   Reply With Quote
rcp track owners.... herman Tracks and GTGs 63 2015.01.22 04:59 PM
New RCP track at one of the most Exotic Car Dealerships in the World RCPMini-z Tracks and GTGs 15 2008.10.29 06:56 PM
Spring setting's on RCP track? marc Mini-Z Science 12 2008.04.15 12:20 PM
RCP Track FS in NY area T-Bolt New York Mini-Z Racing 32 2008.01.26 06:12 PM
RCP Track Innovations Maxfield RCP Tracks 7 2004.10.10 11:57 AM
