Old 2008.04.28, 10:47 PM   #1
russp
russp's Avatar
900 Mah Orion Level 2's
Well, got my Orion 900 Mah Level 2 matched cells today, charged them up and tried them out. Wow, definitely what I should have done before. It's like a mini-turbo in the car. This and a FET upgrade and my car should definitely be competitive with the motor as is. I'd like to buy another set after some more testing so I hope the ebay seller puts up some more.
russp is offline   Reply With Quote
Old 2008.04.28, 11:28 PM   #2
pinoyboy
pinoyboy's Avatar
sounds good Russ. Now you just have to make sure to get some stickier tires to be able to control the extra power with consistency.
I think these are the ones you got correct?
http://mini-zracer.com/forums/showth...=matched+orion
Contact R1 wurks directly and he should probably be able to set you up with some more
Old 2008.04.28, 11:43 PM   #3
russp
russp's Avatar
Yeah, those are the ones. I got them from a seller called snappyshining on ebay
Old 2008.04.29, 05:04 AM   #4
hpgod
Russ you are definately not outpowered anymore. You have better cells then me right now(unmatched intellects and orions). The rest is driving and car setup. You have a track, its time to burn up some tires. For practice I prefer kyosho 20 rears with 3 raicing fronts. That same set of tires has been on my car since christmas running 5-7 packs a week.
Team Scream Racing Matched 900 Mah Min Z Cells JC@TSR Team Scream Racing 36 2012.06.12 06:52 AM
Matched / Graded Orion Cells Now Available R1WURKS Batteries, Chargers and Dischargers 30 2008.07.10 11:36 PM
Battery Capacity Comparison - Rated VS Actual Volt Batteries, Chargers and Dischargers 12 2008.06.08 05:31 PM
orion 900 hv nitroman38 Batteries, Chargers and Dischargers 1 2008.04.10 07:49 PM
900 mAH Batteries revzalot Parts and Hop-ups 7 2004.12.18 12:11 AM
