Old 2005.04.07, 03:30 AM   #1
aeroelasticmz
aeroelasticmz's Avatar
different transmitter performance
HI ppl,
I have tried to change my transmitter around (4 of them) on my overlands and they give very different performances individually.
let say if i used two different transmitter on the same chassis, just by changing the crystal set on the transmitter, it give very different power. especally the power from kt2 transmitter, its a lot more than the kt5.
is there anyway to adjust the power of the throttle in the kt5? apart from the trim button for forward and reverse afdjustment. thanks..
and what is the explanation behind this? is there any limit that you can set for how powerful the throttle can go? or we can 'extent' the limit of the throttle in the kt5? thanks...
aeroelasticmz is offline   Reply With Quote
Old 2005.04.07, 11:33 AM   #2
pajero_overland
pajero_overland's Avatar
Maybe are some transmitters not powerful enough to control the whole OL (steering, throttle etc.). I thinks there IS a limit for the throttle. If you put too mutch throttle on the engine, it maybe get overheated, and if you pull too mutch energie out of the batteries, some may stop working.
---|Live to race, race to live...|---
Mitsubishi Pajero Paris-Dakar Rally
pajero_overland is offline   Reply With Quote
Kyosho Mazda 787B TyHodge07 Parts and Hop-ups 4 2008.10.24 02:57 PM
i-series transmitter weaker? russp i-Series 11 2007.04.17 11:46 AM
Kyosho Mini-z Monster Transmitter Range Problem !! rc_indian Mini-Z Monster MM-01 5 2005.09.15 01:53 PM
1 transmitter for mini-z + 1/10? warthog Miscellaneous Discussion 7 2004.01.25 04:59 PM
Minimum hopups, maximum performance Digisane Setups 52 2003.04.30 05:32 PM
