Old 2011.11.28, 07:02 AM   #1
rajiex
rajiex's Avatar
Diff problem - Maybe
I have a PN 64p diff with the light weight shaft and ceramic ball. I am running 53/12 with 5 ceramic balls. The problem is that the diff seems to bind at one point only. It seems like a high point on the plates but after rebuilding it (sanding the plate), the problem seems to go away but after a couple of runs the problem returns.
Could it be the diff balls are no longer round. They seem to roll around well on a table. I also checked the shaft to see if it has bend in it. What seems to be weird, even if change the diff the problem still exists. Could the problem be on the rims, or bearings on the mount or right rear wheel? Need help, tired of rebuilding the diff but I am getting faster at it.
Raj
Action RC2]
  • MR-03 94MM Ferrari Modena
  • MR-03 94MM Nissan 350Z
  • MR-03 90MM Ferrari 355
  • MR-03 98MM Ferrari 599
  • MR-02 98MM Mosler
  • MR-02 102MM Mazda 787B
  • MA-10 94 Chevy Corvette
  • MA-10 94 Toyota Supra (Drifter)
  • MF-015 Ferrari
rajiex is offline   Reply With Quote
Old 2011.11.28, 07:35 AM   #2
chad508
chad508's Avatar
Motor could be tweaked in the pod, that would cause this as well. Does it feel fine after it gets past this one spot?
PN Racing
R1Wurks
LET's Go Racing
DG Designs
Old 2011.11.28, 08:01 AM   #3
unearthed name
could be the spur gear itself. since it's molded maybe an imperfection will occur.
Old 2011.11.28, 09:07 AM   #4
rajiex
rajiex's Avatar
It only has that one point.. that is the only thing I didnt check.
Raj
Action RC2]
  • MR-02 98MM Mosler
  • MF-015 Ferrari
Old 2011.11.28, 03:19 PM   #5
LED
I also sand down the inside of the gear itself. You can see the little circle from molding. Sometimes they are thicker then the rest. I always sand the entire thing,close my eyes and go over it with my finger nail. If I cant find where the circle is then I'm happy.
the ultimate f1 diff hpgod Mini-Z F1 MF-010, MF-015 11 2007.09.12 12:41 PM
Ball diff changes... HaCo Mini-Z Racer MR-02 4 2007.07.15 04:26 PM
GPM Diff Handling Problem F. Alonso Mini-Z F1 MF-010, MF-015 5 2004.11.07 07:04 PM
Diff problem :| Moses Mini-Z Racer MR-02 12 2004.10.17 08:44 AM
Question an Ball Diff I ordered here. RussF Parts and Hop-ups 3 2003.06.10 12:08 PM
