Old 2014.10.11, 11:56 AM   #1
dameetz
dameetz's Avatar
MR03 VE reverse problem
Just got a 2nd VE for myself. Has 2 problems.....
1)when i try to reverse , the car just shake, sometimes it will get to reverse but most of the time it just shake like the current is not enough to power the motor. If i increase the brake EPA, it seems to be better but do not solve the problem completely and it affects my brake adjustment liking (too strong). Even if I bump up the brake epa to maximum, its reverse speed is not as high pitch sound as the forward speed.
2) from standing still if i apply the throttle, the initial movement is not smooth, like its cogs a bit before moving.
My other VE do not have this problem. Only 2 VE cars are having similar problem in my local club (including mine). The ICS and radio setting are the same as my 1st VE.
What i have done so far to rectify the problem:
- WIRING:I have checked all the wiring, found nothing is wrong. I changed the motor wires, the current wires connecting to the terminal but the problem still exist.
-BATT TERMINAL:The battery terminal is the gold plated SP chassis and its still new. I have tighten the screws on the terminals as well.
- MOTOR: change to a known good working motor, still exist.
Any other thing I should be looking for? Anyone with similar problem like mine? Possible the FET is not good?
Old 2014.10.11, 02:28 PM   #2
Seems you tried everything but a fresh set of batteries. Insufficient voltage will create a low speed reverse as well as cogging going forward.
Old 2014.10.11, 04:11 PM   #3
dwight
mr03ve
I had that problem to after I program it the car worked fine
dwight is offline   Reply With Quote
Old 2014.10.11, 09:52 PM   #4
dameetz
dameetz's Avatar
Tried freshly charged batteries too, problem still exist.
Old 2014.10.11, 09:54 PM   #5
dameetz
dameetz's Avatar
You mean program by ICS? Can you share it pls...
Old 2014.10.14, 08:18 AM   #6
El Tigre
Have you tried re-binding the radio to car? I have had quirky issues that clear up with a rebind of the radio/car. Make sure radio batteries are good too.
El Tigre is offline   Reply With Quote
Old 2014.10.14, 11:26 AM   #7
dameetz
dameetz's Avatar
Changed the motor to PN brushless and the problem is gone. Apparently the stock Orion motor has some issues.
Old 2014.10.20, 12:03 PM   #8
dameetz
dameetz's Avatar
After few days working fine now the problem came back, the PN motor still installed, tried few different motors that I know are working fine with my other VE....the problem still exist....so the stock motor that I mentioned earlier must has been fine.....I m running out of ideas on what to do now.....could it be the FETs are defect? Has anyone tried to replace the VE fets? Are the they the same type as brush motor fets?
Old 2014.10.20, 12:10 PM   #9
TheSteve
VE7FM
I would think it is a solder connection issue somewhere. Fets themselves will never be intermittent, they either work or they don't. It is also possibly a radio issue, not all MiniZ's have the same neutral point - some are very picky.
Old 2014.10.20, 12:34 PM   #10
dameetz
dameetz's Avatar
I already tested with different radio last time and its still there. Can you suggest where to look for for a possible solder connection issue? I just re-soldered the motor wires, check and clean the batt connection terminal, tighten the screws as well without any success on solving the problem.
Let me try to explain again the problem, when I put on the gas, the car jerks a bit and move forward, when I do reverse the car just jerks/shaking, sometime it will go to reverse but most of the time it will only jerk. Compare it to my other VE, the forward movement is really smooth and so is the reverse function. From my view as if the ESC is not giving enough current to drive the motor or possibly only 2 phase of 3 phase needed to drive the motor are working thus why i m suspecting the FETs.
Also as you mentioned, if it has Neutral issue, how do I adjust it? Can the board be calibrated like the normal big scale esc?
Thanks for helping, i m willing to try anything to solve this problem.
Old 2014.10.20, 12:52 PM   #11
Kay-Dee
German Racer
Kay-Dee's Avatar
Hy
Have you tried to program the ESC ?
Use the same settings from the cars which works fine !
Greets
Kay-Dee
Member of the LMN Racing Team Germany
LMN-Tuningparts
Kay-Dee is offline   Reply With Quote
Old 2014.10.20, 12:59 PM   #12
dameetz
dameetz's Avatar
Originally Posted by Kay-Dee View Post
Hy
Done that already, exactly the same setting as my other VE.
Old 2014.10.20, 01:10 PM   #13
TheSteve
VE7FM
I have seen your exact problem before and I am sure it was a connection issue. The reverse just sort of pulses because the VE chassis has very low power in reverse. Forward will cog/hesitate a little.
Make sure the positive tabs on the batteries are making proper contact and aren't just barely making contact because of some interfering plastic.
I have also seen the exact problem with bad batteries.
Either way it is always a lack of voltage getting to the electronics.
Old 2014.10.20, 10:17 PM   #14
KWT
Have you contacted Kyosho? They could repair it for you if the car is still in warranty.
Old 2014.10.21, 01:29 AM   #15
dameetz
dameetz's Avatar
We don't have an actual Kyosho distributor here in my country, only hobby shops and most if not all are not warranted. I have just done replacing all the wiring to the motor and from the batt to the board, clean the gold plated terminals and sand the contact tab which is screw together from the terminal (would direct soldering these improve the current flow?) I ll be testing it again later at the track and report back here if the problem is gone or not.
ASF problem with reverse gizmatron Mini-Z Racer MR-02 4 2013.02.09 08:49 AM
FS: Ultimate MR03 RTR competition package MR-03 Kyosho Ricochet Mini-Z Marketplace 0 2012.03.01 11:23 PM
Mini-Z Reverse Problem corrected on all 2.4 cars ??? SPedregon Miscellaneous Discussion 2 2011.01.30 09:54 PM
mr-03 reverse problem cvt01 Mini-Z Racer MR-03, MR-03 VE, Sports Series 1 2010.09.26 04:13 PM
Problem with glitching, reverse. davkin Mini-Z Science 3 2004.02.22 02:33 PM
