Old 2010.10.31, 12:44 PM   #1
pzchuky
pzchuky's Avatar
Duracell 15min charger
I picked up a Duracell 15min charger to charge @ the track so i tested it out last night and wow it charges the cells up real fast and almost no heat.
I use to charge my AAA in a 4pack on my Hyperion charger @ 10mv/c @ 0.8amp the cells would get hot but not to hot.
How can the Duracell take 1/4 of the time to charge and not have the cells over heat i know that the fan keeps it cool but the charger is dumping 3 amps + in the cells
Am i getting as much of a good charge with the Duracell charger then my Hyperion?
Is it normal that if the light turns off on the Duracell charger and i take the battery's out and put them back in to check if it will put more of a charge in the that i get the flashing light?
I'm thinking it due to the cells voltage that is already @ peak voltage right?
thanks for all the help
Chuck
pzchuky is offline   Reply With Quote
NEW PN Li-Po NiMH NiCd Charger coming soon! PNracing PN Racing 92 2012.08.22 01:10 AM
Apple Battery Charger arch2b Batteries, Chargers and Dischargers 5 2010.08.04 09:40 AM
FS: Rayovac IC3 15min Charger sykdevil Mini-Z Marketplace 3 2007.04.09 09:41 PM
Duracell 30 min charger edhchoe Parts and Hop-ups 2 2004.10.28 04:42 PM
