Old 2019.09.15, 09:15 PM   #1
DISC damper question
So, I am always frustrated when I try to switch springs or clean or resand my disc damper. It is always a hassle. The post always unscrews from the bottom instead of the top when I try to loosen the top screw. I wish it was reverse threaded on the bottom so it wouldn't come loose when you unscrew the top screw. I always have to grab the lower flange with a pair of needle nose pliers to get the top screw out. Although the flange is not part of the sliding surface, it still gets all marked up. Does anyone have a better trick to deal with this issue?
I realize it is not really a big deal, but on the other hand some of you have a lot more skill and experience than I do. Thanks for the help!
Old 2019.09.15, 09:59 PM   #2
mugler
thread lock on the post screw can be your friend here. I only use the weakest purple version, have experienced mighty lock ups even with the blue.
Old 2019.09.15, 10:16 PM   #3
That is why I avoided it, but I should try some purple.
Old 2019.09.15, 11:03 PM   #4
mugler
yes purple did the job for me with no issues.
Old 2019.09.16, 12:02 AM   #5
I use blue for the lower screw and purple for the top. I almost never remove the lower screw unless I am changing the post so I prefer it being stuck in place until I need to remove it.
Tri Damper plate question Mania PN Racing 4 2014.12.09 09:04 PM
Motor wires with disc damper? pomme de terre Mini-Z F1 MF-010, MF-015 6 2011.07.23 11:02 AM
WTB:PN 94-98mm LCG Mount V2 and some disc damper parts TannerT Mini-Z Marketplace 2 2009.10.07 05:11 PM
what size disc damper??? bermbuster Mini-Z Racer MR-02 10 2008.03.14 12:50 PM
Atomic RML disc damper problem TheRinger Mini-Z Racer MR-02 2 2007.12.18 11:21 PM
