2009.04.15, 12:29 PM
#16
Originally Posted by dabinn
No, the voltage level is different.
But you can try to find another device/converting cable called "USB to TTL converter". It convert USB to UART/TTL level (about 5V), and can fit the signal voltage of MINI-Z ASF(but not AD band & dNaNo). It is not very easy to buy, but you can find them on some website like this:
http://www.ftdichip.com/Products/Eva...s/TTL-232R.htm
You may need to link the VCC & SIGNAL pin with a 4.7k resistance for this cable, or MINI-Z will think you don't connect anything on it. But the problem is...I can't make sure it will work or wont, for I have never got this device before.
This was what I was thinking about doing, but shorting the Rx and Tx pin's with a 4.7k - 10k resistor...
The cable I was looking into buying was this one:
http://export.farnell.com/ftdi/ttl-2...questid=430655
It should work, but i can't give you any guarantees...
Reflex Racing International Team Driver
Alberto Carvalho - Portugal
2009.04.15, 01:00 PM
#17
dabinn, do u know it this thing might work?
http://my.farnell.com/ftdi/usb-rs232...tor/dp/1686451
and here's the data sheet
http://www.ftdichip.com/Documents/Da...2_PCB_V101.pdf
the thing seems to drop the voltage down too but at what voltage does the ASF board works when connected to the computer?
Mini-Z AWD 2.4Ghz 94mm
Mini-Z AWD DWS PN A-Arm 2.4Ghz MR03 board 98mm
Mini-Z MR-02 2.4Ghz
Mini-Z MR-03
FX-101 Dnano 360 Modena
2009.04.15, 10:21 PM
#18
pretty cool project...
2009.04.16, 12:38 AM
#19
Originally Posted by z3zinho
We're thinking about the same thing.
I think it should work,too. But somebody needs to try out.
2009.04.16, 12:44 AM
#20
Originally Posted by ub0211042
Hi,
If you use this "USB RS232 to converter", you still need a I.C.S.cable for converting MINI-Z singal into RS232 voltage level at first.
2009.04.17, 02:49 AM
#21
Hi dabinn,
Just to confirm few things before my parts arrive and start on this lovely project:
VCC - Red wire is from 1k Resistor
SIG - White wire is from 39k resistor
GND - Black wire is from “E” leg of both transistor and diode
and just wondering why kyosho's only have 2 wires SIG and GND?
Thanks.
Mini-Z MR-02 2.4Ghz
Mini-Z MR-03
2009.04.17, 09:17 AM
#22
Looking to the converter shcematic and the foto, Vcc, Gnd and Signal seem to be right.
As for the 2 vs 3 wires, with only two wires like Kyosho has, you need to have batteries in the car to use the ICS, with the 3 cable setup, the computer alone can suply the power to the board
2009.04.17, 11:50 AM
#23
Hi dabinn,
Thanks.
That would be a cable for the new I.C.S USB adaptor. The USB one outputs fixed singal voltage (maybe 3.3v or 5v) to mini-z, and doesn't concern about what voltage of Mini-Z is, so only two wires are needed.
The old I.C.S. cable uses a diffrent way. It can "generate" various singal voltage according to opposite VCC.
ex. When PC sends a 12v signal through the RS232, this signal triggers the transistor to make the VCC of MINI-Z flow into the SIG line. So mini-z will get a signal that with the same voltage of it's own VCC. Voltage is been converted and meanwhile the signal is been transfered.
2009.04.17, 12:03 PM
#24
You are right. An additional VCC line can supply the power from the PC.
But for some safety reason, we didn't modify the circuit to do that. Batteries in the car are still needed for this cable.
2009.04.17, 03:48 PM
#25
thanks guys for the replies
Mini-Z MR-02 2.4Ghz
Mini-Z MR-03
2009.04.17, 08:46 PM
#26
The name is Tim
now how to integrate that in a novak millenium pro. just like adjusting a cyclone
Team Associated
2009.04.17, 10:22 PM
#27
Do you mean the function like my ICS box?
http://www.minizracer.com/forums/sho...6&postcount=28
2009.04.18, 02:32 PM
#28
The name is Tim
yup.on the old millenium pro it has a place for the cable to plug in to. now if you can do it it would be awsome
Team Associated
2009.04.20, 01:22 PM
#29
i have a problem with the ICS, it seems that the pc doesnt detect the car...
im using the DIY cable with a RS232 to USB converter and only the USB to serial converter were detected on my pc which i checked on the device manager.
few Q's here:
1. how do i know it the cable i built is working
2. do i need to turn on the power?
3. how will the red LED lights up?
4. how to know if its connected to the PC
5. anyway to check of the DIY thing working correctly
6. which is the most important component of this ICS? transistor?
Thanks.
Mini-Z MR-02 2.4Ghz
Mini-Z MR-03
2009.04.20, 03:15 PM
#30
few Q's here:
Thanks.
1) If it worsk its OK :P
2) Put in batteries in the car, Turn on the car while pressing the pairing button. The LED should light up.
3) just ON
4) In the program change a setting, then write to the car, press the reset button (the seting you changed will go back to default) and read from the car. The setting should go back to what you made it.
5) See point 4
6) all of them.
Do you have the manual downloaded ? It discribes how you now wich com port to use. Maybe check that to.
Good luck
