Old 2016.11.03, 08:22 AM   #1
helee4
helee4's Avatar
Send a message via MSN to helee4 Send a message via Yahoo to helee4 Send a message via Skype™ to helee4
Steering lost straightness
This is a slightly different topic then fixing the centering lots of us experienced with the MA, and I am again looking for advice..
After all the centering fix I did, my MA seems to track straight and centering fine after turn. But it seems to me that after driving for like couple of laps, the car will suddenly lost its straightness, and I have the adjust the steering trim and it will track straight again. I mean it still centers fine, but I am not sure what causes it lost its straightness. Any idea?
helee4 is offline   Reply With Quote
Old 2016.11.03, 08:30 AM   #2
cowboysir
My first thought would be the potentiometer is loose in its housing when you correct the steering every couple laps is it back and forth left and right or are you correcting the same direction each time?
my custom body album...
Old 2016.11.03, 11:13 AM   #3
helee4
helee4's Avatar
Thanks for the tip! Let me pay attention to that tonight.
Old 2016.11.03, 11:16 AM   #4
TheSteve
VE7FM
Also check your servo gears, you could have a broken/damaged tooth that is skipping.
Old 2016.11.03, 12:30 PM   #5
poochy
Or tx steering wheel tensioner spring too loose and wont spring back to center.
poochy is offline   Reply With Quote
Old 2016.11.03, 05:37 PM   #6
MiniDeRub
I actually sent my buggy back to kyosho for doing the exact same thing right out of the box. They told me they replaced the "pot" and sent it back. running fine now.
MiniDeRub is offline   Reply With Quote
МА-010 with MR-03 board - steering travel problem Bodom Mini-Z AWD MA-010, MA-015 35 2012.03.15 08:39 PM
Help. Steering won't center. Phenochilus Mini-Z Racer MR-02 8 2007.07.10 09:51 PM
MM02 steering problem pyro147 Beginner Questions 6 2006.03.29 02:54 AM
iWaver02 steering twitch / steering steps FIX!!! trueno92 iWaver 0 2005.04.23 12:09 AM
gpm steering parts problem marlboro Mini-Z Overland MV-01 1 2004.06.29 07:27 PM
