Old 2014.12.23, 01:13 PM   #1
MR-03 front arm spring spacer
anyone recall who made these spacers? they are installed on the bottom spring perch.
Old 2014.12.23, 02:18 PM   #2
R-246 makes a set and Atomic has one that is adjustable. Either 3 Racing or Hot racing has them as well. PN makes individual ones.
Old 2014.12.23, 02:27 PM   #3
do you recall the specific name? i tried searching for them earlier today but didn't see anything in the results.
Old 2014.12.23, 04:15 PM   #4
Mania
http://www.rcatomic.com/atomic/index...oducts_id=4747
http://www.rcatomic.com/atomic/index...oducts_id=4732
http://www.kenonhobby.com/PN-Racing-...e_p_43001.html
Mania is offline   Reply With Quote
Old 2014.12.23, 04:31 PM   #5
thanks for the links. what i'm looking for are rings or shims to adjust pre-load of the springs. i have a pair of blue shims installed on a car but no longer recall where they came from or what the kit was called. they work very much like the plastic cups in the first link product.
PN Racing MR02 Front Delrin Spring Holders? BlackBerry PN Racing 2 2012.03.06 05:52 PM
PN Racing MA-010 AWD Front Double -A- Arm Suspension. eztuner12 Mini-Z Racer MR-01 0 2009.05.10 09:30 AM
Looking for F1 front spring set and bda52 Mini-Z F1 MF-010, MF-015 6 2005.04.08 11:57 AM
Front Spring Setups.... geoffrey109 Setups 0 2005.04.03 02:15 PM
