Old 2019.04.28, 09:27 AM   #1
HFAY Season 28
HFAY Season 28
I know this is a bit early but we will be jumping back into HFAY with S28 and eager to see what that season is going to look like with regard to tracks. We have not test fitted the space yet but should be able to handle all HFAY tracks.
Old 2019.04.28, 09:25 PM   #2
MTSEO
Guest
Posts: n/a
Seoz was able to fit all of season 27 tracks, some were a bit tight but they fit. We should be able to fit any hfay track also.
Old 2019.04.29, 12:34 PM   #3
Tri Cities did not have trouble fitting any tracks, although we might if they were much bigger than Season 27. It would really help us out as well to get started on this. We will not be able to race in July, so I am hoping we can get the tracks sorted out early so we can run races 1 and 2 in June.
Old 2019.05.03, 01:14 PM   #4
bobbyz
I'm guessing a new set of rules for Season 28 will be coming out sometimes soon, but I am wondering about weight limit specifically, as I don't recall seeing a minimum weight limit in the older versions of the rules.
bobbyz is offline   Reply With Quote
Old 2019.05.03, 01:50 PM   #5
Iím fairly certain season 23 rules had a min. Weight requirement of 170-175G.
Old 2019.05.03, 02:11 PM   #6
bobbyz
Read through the PDF of Season23, and still don't see any minimum weight limit info. It should be somewhere on Page5 or Page6 of the Vehicle Tech Regulations. Maybe it's missing on my PDF version???? I have my car set at abt 173g currently, but just wanted to verify. Thx
HFAY Season 27 TyGminiz How Fast Are You? Online Points Series 298 2019.06.06 01:52 PM
HFAY 70-turn Season 6 Spec Motor Tests schmenzer How Fast Are You? Online Points Series 27 2009.03.09 01:49 PM
HFAY 70-turn Motor - On Track Tests schmenzer How Fast Are You? Online Points Series 1 2008.06.04 05:31 PM
HFAY OLPS Ann Arbor Videos hobbycar How Fast Are You? Online Points Series 16 2007.11.03 08:02 PM
