Go Back   Mini-ZRacer.com Forums > Mini RC
Old 2011.02.05, 09:59 PM   #1
EQMOD
Losi 1/36 scale Micro T with Steering Gyro Assist for stability
Here is another mod - A 1/36 scale gyro steering assisted Losi Micro T. I had to add the gyro to assist the car on the drag runs specially with a free running rear differential where on uneven road surface, the wheels tend to bounce and rotate at different speeds (due to its diff mechanism). The gyro will simply make the necessary heading corrections keeping the drag runs straight
To mount the gyro, i simply need to use the available space where the power switch is. Switch was removed as i am using a different ESC (brushless) which doesnt require a power switch. That compartment space is actually the best protective spot for the gyro sensor;
with the servo cover trimmed and re-attached and secured with three screws;
Gyro neatly mounted and secured with the murata sensor perpendicular to the car's horizontal plane;
With the rest of the electronics in place (2.4Ghz rx and 10A Brushless ESC)
Here is a quick glance of the murata gyro sensor through the switch hole. The gyro sensor tin cover must be secured.That actually easily comes off if its not secured;
Checking if the weight distribution is still ok. It will be - as the added electronics barely induce any significant weight on the entire platform.
VIDEOS;
Desk top tests, and gyro gain adjustments;
http://www.youtube.com/watch?v=R5Acq5aCmOg
Outdoor drag run (take note of the stability)
http://www.youtube.com/watch?v=tuxLk1n_kqk
Rough road tests - simply driving straight (ignore the crashes )
http://www.youtube.com/watch?v=lg6QoVsh7tU
EQMOD is offline   Reply With Quote
Gyro assisted steering on a Mini-Z EQMOD General Discussion 4 2011.04.09 03:53 PM
1/24th scale losi spec class!!!! yasuji RCKenon, Baldwin Park CA 3 2010.08.26 03:30 AM
Losi 1/36 Micro-Desert Truck arch2b Mini RC 57 2008.04.05 09:30 PM
Losi Mini-t Micro 1/36 scale at Ihobbyexpo RCPMini-z Mini RC 3 2006.10.20 08:14 PM
