Old 2019.04.28, 09:27 AM   #1
HFAY Season 28
HFAY Season 28
I know this is a bit early but we will be jumping back into HFAY with S28 and eager to see what that season is going to look like with regard to tracks. We have not test fitted the space yet but should be able to handle all HFAY tracks.
Old 2019.04.28, 09:25 PM   #2
MTSEO
Guest
Posts: n/a
Seoz was able to fit all of season 27 tracks, some were a bit tight but they fit. We should be able to fit any hfay track also.
Old 2019.04.29, 12:34 PM   #3
TPDazzle
Tri Cities did not have trouble fitting any tracks, although we might if they were much bigger than Season 27. It would really help us out as well to get started on this. We will not be able to race in July, so I am hoping we can get the tracks sorted out early so we can run races 1 and 2 in June.
Old 2019.05.03, 01:14 PM   #4
bobbyz
I'm guessing a new set of rules for Season 28 will be coming out sometimes soon, but I am wondering about weight limit specifically, as I don't recall seeing a minimum weight limit in the older versions of the rules.
Old 2019.05.03, 01:50 PM   #5
Iím fairly certain season 23 rules had a min. Weight requirement of 170-175G.
Old 2019.05.03, 02:11 PM   #6
bobbyz
Read through the PDF of Season23, and still don't see any minimum weight limit info. It should be somewhere on Page5 or Page6 of the Vehicle Tech Regulations. Maybe it's missing on my PDF version???? I have my car set at abt 173g currently, but just wanted to verify. Thx
Old 2019.05.05, 08:27 PM   #7
briankstan
SLMZ / HFAY
briankstan's Avatar
you are right it's not in there. Must have got overlooked in the revision. It'll be back in for the next season. 170grams is the minumum weight.
as for the tracks for the upcoming season. Salt Lake Mini-Z can only fit the tracks that fit within 8 tiles wide x 12 tiles long. We can fit the following tracks in our space.. 1,2,3,4,6,12,13,14,15,16,18
Old 2019.05.06, 12:09 PM   #8
bobbyz
Sounds good Brian, thx for the info.
Old 2019.05.07, 10:27 AM   #9
TPDazzle
After looking over the available tracks, our vote in Tri-Cities is:
2, 13, 14, 15, and 18.
Old 2019.05.07, 10:41 AM   #10
briankstan
SLMZ / HFAY
briankstan's Avatar
I would vote for the following tracsk.
2,6,13,15,18
Old 2019.05.08, 03:12 AM   #11
MTSEO
Guest
Posts: n/a
3,6,14,16,18
That is my vote for season 28 track list.
Old 2019.05.17, 02:56 PM   #12
art4242
We should be able to fit any of the HFAY layouts in our space. No huge preference on any of the tracks, so ok with anything that gets chosen.
art4242 is offline   Reply With Quote
Old 2019.05.21, 11:02 PM   #13
TPDazzle
Not many votes cast yet Here are the results so far, remember votes are due by the end of May, however, I am wondering if it might be just as good and a lot simpler to just put all the SLC- friendly tracks into a hat and draw 5 in race order.
3 votes: track 18 (we must all like the high speed sweeper)
2 votes: track 15
2 votes: track 14
2 votes: track 13
2 votes: track 6
2 votes: track 2
1 vote: track 16
1 vote: track 3
Old 2019.05.21, 11:16 PM   #14
mugler
My top 5:
2,13,15,16,18
Old 2019.05.22, 06:15 AM   #15
No real preference from me, iíll Run whatever is chosen.
HFAY Season 27 TyGminiz How Fast Are You? Online Points Series 298 2019.06.06 01:52 PM
HFAY 70-turn Season 6 Spec Motor Tests schmenzer How Fast Are You? Online Points Series 27 2009.03.09 01:49 PM
HFAY 70-turn Motor - On Track Tests schmenzer How Fast Are You? Online Points Series 1 2008.06.04 05:31 PM
HFAY OLPS Ann Arbor Videos hobbycar How Fast Are You? Online Points Series 16 2007.11.03 08:02 PM
