Old 2015.11.27, 01:52 PM   #16
art4242
Originally Posted by refsiul22 View Post
Anyone tried Marka tires V6 ? Could you comment and compare with former versions V1 and V5 please?
The combo that has worked for me is V5 F15/ V1 R10...
I've been using the V6 tires for the past few weeks, they are a definite improvement over the V5's. I've been running V6 front 20's and 25's. About the same grip levels as the corresponding V5's, but last much longer. Subjectively they feel like they have a smoother steering response.
Also I can run the V6's larger, with V5's I had to run the 20's at 22.0mm or below to prevent traction rolling. With the V6's I've been starting at 22.5mm and no rolling.
The only disadvantage is they take a little longer to break in, but the better life is well worth it.
art4242 is offline   Reply With Quote
Old 2016.01.05, 11:36 AM   #17
refsiul22
refsiul22's Avatar
Thanks Art. Definitely gonna try them.. btw, I ran V5F15 @23.0mm without rolling problems (big track, soft springs, 39-50T)
Have you tried sanding them (high grit) after truing? It reduces break-in time practically to zero.
Railyard Hobbies Racing - 2015 abasualdo Reading MiniZ Racers, Reading PA 91 2015.06.24 03:00 AM
Microsoft MIX 2011 - Mini-Z racing mdowney Events 51 2011.04.25 08:30 PM
MC3/ Reflex Racing Points Series info Sinister_Y MC3, Toronto, ON, Canada 0 2011.01.26 09:03 PM
building a pan car jonnywachter Mini-Z Racer MR-02 49 2009.07.07 04:53 PM
3 Racing tires for the Monster. Bad Company Mini-Z Monster MM-01 2 2004.07.21 07:49 PM
