Old 2017.01.01, 04:41 PM   #1
Nsxtat
Reverse king pin on pn caster upper arms?
I am interested in getting a set of pn racing caster upper arms for the mr03. I want to keep my reverse king pin setup with the stock king pins. Is this possible, or do I need to buy a set of pn racing delrin ball and king pin set to achieve this? Thanks.
Nsxtat is offline   Reply With Quote
Old 2017.01.01, 05:43 PM   #2
cowboysir
it is hard to fit metal balls/kingpin ends into alloy arms to get that reverse kingpin setup so if you want caster and retain reverse kingpin setup you have can either get the pn setup as you suggested (delrin balls, etc) or get a center tower arm mount for the arms which gives you the caster you are looking for
my custom body album...
Old 2017.01.01, 07:01 PM   #3
Nsxtat
Thanks for the response , I figured that would be the issue. I actually want it for the camber more than the caster, but that fact that it has both is great. I am slowly going from casual to just wanting to keep up with the fast guys.
PN 1 degree upper arms monkeyZ PN Racing 3 2015.11.07 10:05 PM
Front king pin mod? stefano225 Beginner Questions 3 2015.04.14 12:18 PM
More Caster Options for the PN Front Suspensions? 02/03 A-Arm, 03 Upper Arm? Felix2010 PN Racing 9 2011.07.01 09:55 PM
mr03 upper arms dvsstrike Atomic 1 2010.03.03 10:57 PM
Cracked King Pin Holder. What to Do? RussF Mini-Z Racer MR-02 8 2008.02.12 12:58 PM
