Old 2007.10.10, 02:29 PM   #1
DeOz
SOLD: The mother of them all, Mini-Z AWD package
1. Name - Dana Osborn
2. Location - Fremont, CA USA
3. Contact –
If you have any questions or would like to throw me an offer please send me a PM or an e-mail. Please, please no low balers. This package is worth a LOT of money and I am selling it at a GREAT value.
- Dana
drosborn_jr@yahoo.com
4. Description -
Up for sale is my best Mini-Z AWD race car with all the left over mini-Z parts and accessories that I have left. I will be making this one package for the car and spare parts, and an add on package for the rest of the mini z accessories. Who ever buys this will be getting a great race proven wining car for more than half off what it would cost to build. All you will need is a controller with some crystals and you are good to go.
***AWD race car***
- The car started off as the full ball bearing version performance hard plastic chassis build it your self kit. I no longer have the factory Kyosho box for this.
- Atomic mods ceramic ball bearings for the center shaft, main diff bearings, and rear SAS suspension knuckles, Standard Kyosho ball bearings on the front knuckles
- Delrin steering gears
- Atomic mods 98mm extension kit
- Atomic mods black delrin 98mm spur gears
- Atomic mods SAS rear suspension kit
- Atomic mods 2 deg camber knuckles for SAS rear suspension
- Atomic mods 2 deg caster arms for SAS rear suspension
- NEW style Atomic mods aluminum rear SAS shocks
- Atomic mods blue, orange, and silver springs for SAS rear suspension
- Atomic mods plastic/delrin ball diffs front and rear, they have been re-built to my specs
- Lay down crystal adapter to fit any body
- Atomic mods aluminum heat sink and air scoop motor holder
- Atomic mods monster stock motor
- PN racing metal pinion gears
- PN racing aluminum motor holders with different sizes to allow you to run all sorts of gear ratios from A1/B1, A1.5/B1.5, to A3.5/B3.5 (more gear ratios than you would know what to do with)
- PN racing 1.5 Deg camber front knuckle
- Kyosho spring set for the suspension up front
- PN Racing orange shims for lowering
- Atomic mods Ti axle shafts
- Aluminum hex nuts all around
- Upgraded wire all around, Batt has been directly soldered to the board and the motor is running the same larger gauge wire.
- Atomic mods front white dish 3.5mm offset “narrow” wheels with stock kit rubber
- Atomic mods rear white dish 3.0mm offset “wide” wheels with stock kit rubber
*** Spare parts, extra tuning parts, parts for future re-builds, wheels/tires, etc. ***
- Lots of extra motor/battery connection wires, some stock some PN racing upgraded wire.
- Two stock kit motors
- 4 extra motor cans with end bells.
- 2 sets of extra PN racing brushes (for PN can)
- 3 extra motor resistors
- More stock screws, washers, etc than you can shake a stick at
- Two stock never used diffs
- PN racing shim set 0.1, 0.2, and 0.3mm shims
- Extra diff gears for future re-builds
- Every spur gear for all size widths
- Atomic mods re-build kit for Ti-universal shafts
- 4 pairs of stock AWD “wide” mesh wheels in every offset they offer
- 7 pairs of stock AWD “narrow” mesh wheels in every offset they offer (with a couple duplicates)
- 7 pairs of “narrow” tires ranging from PN racing 20deg to stock kit tires.
- 4 pairs of “wide” tires ranging from PN racing treaded to stock kit tires.
- Two plastic Mini-Z car stands.
- White Enzo body with wing
- Red Enzo body with holes drilled to clear the front suspension
- White Ford GT-40 body with holes drilled to clear the front suspension
- Malaren GT body with holes drilled to clear the front suspension
- Core transponder
*** Non Chassis parts that can be added to the package ***
- PN racing bearing cleaning case
- PN racing wide tire tape roll
- PN racing AAA charge holder
- 33 Duracell rechargeable 1000mAh Ni-Mh cells
- Tamiya Mini Speed Checker dyno
Here are pictures of the car and all the parts:
http://www.osbornhouse.com/rc/miniz/awd/
5. Price -
When you add up all the parts and accessories the total comes to well over $800.00.
As for my price; For the car and all its spare/tuning parts I am asking $300.00 shipped OBO, and if you want the non chassis parts as part of the package I am asking $330.00 shipped OBO.
DeOz is offline   Reply With Quote
Old 2007.10.10, 02:44 PM   #2
please add the required information per the requested format in the sticky rules for this section
Old 2007.10.10, 04:17 PM   #3
philly123
Need a Fet Job?
philly123's Avatar
wud u consider selling just the car because i am interested but i dont need all those parts ill offer 210 for the car as shown
philly123 is offline   Reply With Quote
Old 2007.10.11, 02:08 PM   #4
DeOz
The only thing I can see that I am not in compliance with is this:
A. For Sale Post format - All items for sale will use the following format:
3. Contact – Already stated
4. Description - Already stated
5. Price - Already stated
Old 2007.10.11, 02:09 PM   #5
DeOz
Sorry at this time I would like to sell the car as a package.
Old 2007.10.11, 02:18 PM   #6
i don't know how to make this more clear... read the rules and post accordingly. they are very simple and very easy to follow. i've edited your post with the follow-up info you posted (thank you) however as i assume you are an intelligent person, i should not have to do this for you nor anyone else. i don't think it's a huge thing to ask that someone post in the requested format yet we find ourselves being chided for correcting people is it that you did not read the rules or that you did and you just don't care? seriously, which is it? not to take this out on you but it's often frustrating to deal with such mundane things as making sure someone actually reads the rules and follow them, especially when they are so simple in this case
fyi, it's a great package you have for sale
Old 2007.10.11, 02:52 PM   #7
DeOz
You have a PM
Old 2007.10.11, 03:36 PM   #8
thank you for the message.
just so everyone is clear, i am not pointing DeOz out to single him out but to address a larger problem of people not seeming to be able to follow simple rules.
we will institue a zero tolerance policy if it continues.
Old 2007.10.11, 10:39 PM   #9
Toodeep
See if my brother wants it. He lives in Union City. So 270 picked up? Ill ask him see what he says.
Toodeep is offline   Reply With Quote
Old 2007.10.12, 05:38 PM   #10
DeOz
Shoot me an e-mail if your brother is interested maybe we can work out a deal on the price.
- Dana
Old 2007.10.12, 06:15 PM   #11
Draconious
Draconious's Avatar
Since the thread is alreacy "Crapped" into another topic by a moderator I will add this: It should not be too hard to add code, when in this area of the forum, when the post topic button is pressed to pop up a 2nd window that has the "rules" on it... they have to click accept before posting.
Old 2007.10.14, 11:17 PM   #12
DeOz
Please let’s keep it on topic from now on.
Old 2007.10.22, 12:30 PM   #13
DeOz
^^Bump^^
Make an offer
Old 2007.10.29, 03:59 PM   #14
minittrackmann
minittrackmann's Avatar
any trades. i have a nice xray m18 with c/f chassis, and nice electronics.... lmk...
minittrackmann is offline   Reply With Quote
Old 2007.10.30, 05:55 PM   #15
DeOz
Car has been sold
FS: My Latest For Sale List (((((UPDATED OLD THREAD)))) Draconious Mini-Z Marketplace 68 2009.03.01 06:02 PM
FS: AWD and MR02/15 parts Sinister_Y Mini-Z Marketplace 20 2007.04.01 07:25 PM
Which Mini to get? MR-02 speical edtion? pekopeeus Beginner Questions 7 2007.02.24 10:00 PM
official kyosho awd product description herman Mini-Z AWD MA-010, MA-015 16 2005.09.30 10:18 PM
Looking to trade my micro rs4 roller for a Mini z aznfknpride Miscellaneous Discussion 0 2004.07.05 10:13 PM
