Old 2006.04.13, 01:23 PM   #1
bixu
Send a message via MSN to bixu
miniz z awd conversion to overland
somebody try to make a Overland 4x4 with a miniz awd chassis?
bix
bixu is offline   Reply With Quote
Old 2006.04.13, 09:18 PM   #2
pomme de terre
pomme de terre's Avatar
It would be weird and difficult since one is solid axle and one has independant suspension. I also dont know how you would keep the driveshaft in place while the overlands suspension is in movement or when its articulating...
pomme de terre is offline   Reply With Quote
Old 2006.04.14, 10:55 AM   #3
lilskipro587
Wants a TTTT
lilskipro587's Avatar
model it after a xmod truck. the rear and front articulates around the driveshaft it should work if i had an overland and a extra awd i would try it.
lilskipro587 is offline   Reply With Quote
Old 2006.04.14, 02:56 PM   #4
pomme de terre
Well one thing about the xmod truck is that the suspension really isnt all that great... especially for an offroader.
If you look at most bigger scale 4WD solid axle trucks, youll see that they usually use dogbones of some type to drive the front axle and another for the rear axle. I havent seen a solid axle truck with a driveshaft to the axles before...
Old 2006.04.15, 08:27 AM   #5
lilskipro587
Wants a TTTT
yea the dogbones in the xmod trucks arent great at all they break sorta easily
Old 2006.04.15, 04:06 PM   #6
DogbreathRacing
MINI-Z MONSTER GARAGE
DogbreathRacing's Avatar
Check out the old Tamiya Bruiser, a 4X4 with straight axles, front mounted motor, center mounted transfer case, ladder frame, and leaf springs.....one of the most "Real" R/C's to ever be built.
MR02RM, MR02MM, MZM,
Pro-Pulse Pro T-100 1/18 4X4,
Old 2006.04.16, 08:37 AM   #7
rlc77
Hippygeek
rlc77's Avatar
DB. That brings back memories. I used to own one of those back in the late eighties. I sold it to my best friend and his ex wife took off with it when they divorced. He wasn't happy about it. Yours seem to still be in good condition.
You should always listen twice as much as you talk--that's why you have two ears and one mouth.
rlc77 is offline   Reply With Quote
Old 2006.04.16, 09:21 AM   #8
what were those trucks rcp used for his rock crawling course? it looks like soo much fun typically i don't care for monster trucks but the idea or trials course driving is tempting.
Old 2006.04.16, 01:38 PM   #9
G-Class
Big Slugger
G-Class's Avatar
Tamiya really did a good job with that truck! That is sweet!
Mercedes Benz G55 AMG, Black, X-Speed motor, Titanium 10-34t, High Grip Tires Type B, spare tire mounted on the hood.
My Gallery NEW OL PICS UPDATED:07/27/2006
"There's a momentary pause while a Nomex finger stabs at any button relating to safety." Top Gear Magazine FEBRUARY 2007
G-Class is offline   Reply With Quote
Old 2006.04.16, 05:28 PM   #10
Draconious
Draconious's Avatar
Can always wait for my AWD chassis kits
This time the design is 99.999999% done... I just have to find an affordable source to make the parts... however it would not make a very good rock climber... its more of a rally chassis, buggy, stadium truck... but it has a LOT of ground clearance with monster rims/tires so who knows...
Its just a solid center axle, with 4 half shafts at each tire. The half shafts are what I fear will break... so I am going directly to titanium as the stock material... this kit will NOT be cheap, and I am expecting it to not need any after market/hop ups at all... but who knows... there will be a width, and length kit to make it longer for trucks and wider for the monster rims... F1 tires should fit on it fine, so possibly a few lexan body mount kits for the Nascar lexans...
Old 2006.04.17, 09:33 AM   #11
Stoovey
Draco, what kind of tranny setup will your AWD have? Belt? Shaft-drive? It would be cool if you could make a Monster AWD design using axle-mounted motors, like a Clod, and not have it be bigger than stock.
Stoovey is offline   Reply With Quote
FS: Overland, AWD alloy GT3 Mini-Z Marketplace 8 2007.07.16 06:21 PM
official kyosho awd product description herman Mini-Z AWD MA-010, MA-015 16 2005.09.30 09:18 PM
Kyosho Announces AWD Mini-Z! mini-z Mini-ZRacer.com Announcements 0 2005.08.25 12:24 PM
overland conversion? miatafreak Setups 1 2004.02.22 07:10 PM
