Old 2006.11.19, 10:55 AM   #46
ChrisJuliano12
Mr02
pinoboy, sorry for spam guys but can you check my thread again?
ChrisJuliano12 is offline   Reply With Quote
Old 2006.11.22, 01:50 PM   #47
pchan0
Team ShoBoi
pchan0's Avatar
Send a message via ICQ to pchan0 Send a message via MSN to pchan0
Took some pictures of my MR-02 again...
pchan0 is offline   Reply With Quote
Old 2006.11.22, 08:23 PM   #48
Bob_Zahn
Peter
Your car is looking very good.
Could you send me the setup you are using now for ZZ Hobby?
Front springs and travel along with springs in rear dampener?
thanks
Bob_Zahn is offline   Reply With Quote
Old 2006.11.22, 10:51 PM   #49
pchan0
Team ShoBoi
pchan0's Avatar
Originally Posted by Bob_Zahn
Peter
thanks
Thanks Bob, for the front I run silver atomic spring, their second lowest travel spring holder with .2mm spacer. For the rear disc damper its top medium and bottom hard spring.
Old 2006.11.23, 01:57 AM   #50
Ninja
Mechanic
Ninja's Avatar
ok here is my current 02, the wheels are so sweet, they are the only set I have seen that are actually this deep looking, they are 3mm offset in the rear, and 1mm offset in the front. The motor is a PN BB can with stock armature in it. Iwaver alloy motor mount and roll shock set. these are actually nicer in person, and great quality for even better price. the tie rod is 1* toe-in, and the JPL bar is actually the TAGU model 1.5 caster and 0.5 camber. alloy Kyosho Knuckles. and PN Ball Diff. And it might be hard to believe from the looks but yes I actually race this body. Stay in front, and it dont get beat up
sorry for so many pics, but this is the first time I have ever gotten good pics of my Mini-Z and want to show it off !!!!!!!!!CLICK TO SEE FULL SIZE!!!!!!!!!
Real Racers Do It Sideways.
Old 2006.11.23, 10:38 AM   #51
builthatch
yes, it's a boxer
builthatch's Avatar
pchan, do you use some sort of CF-look adhesive sheet? I noticed it atop the chassis and also on your Futaba module mod, on the xtal...
Is is the stuff like what Folia-tec makes? i like how the squares are not too big...
Reflex Racing :thumbup:
Old 2006.11.23, 10:47 AM   #52
MINIz guy11
Hibernation ON!
Send a message via AIM to MINIz guy11 Send a message via MSN to MINIz guy11 Send a message via Yahoo to MINIz guy11
Ninja, is the Tagu Tower Bar different than the JPL one?
Airtronics M8 | MR-02 | F1 | MR-015 | Overland 'Evo Nellied' | MR-02 Pan Car
MINIz guy11 is offline   Reply With Quote
Old 2006.11.23, 11:13 AM   #53
pchan0
Team ShoBoi
pchan0's Avatar
HPI Racing CF sticker sheet, the pattern for this scale is perfect.
Old 2006.11.23, 12:59 PM   #54
Ninja
Mechanic
Ninja's Avatar
just a little better quality. and alot bigger price tag, but it was on the car when I bought it used.
Old 2006.11.23, 03:07 PM   #55
MINIz guy11
Hibernation ON!
Alright, but would I need a new tierod like the JPL one? What I mean is that will the stock tierod let the wheels point straight?
Old 2006.11.23, 06:53 PM   #56
Ninja
Mechanic
Ninja's Avatar
no, you will have slight toe-in if you change the camber with the JPL upper bar. if you want the wheels perfectly straight do this, if you get a 1.5* camber bar, get a 1* toe-out tie rod to compensate
Old 2006.11.23, 07:20 PM   #57
MINIz guy11
Hibernation ON!
Oh, I've been told otherwise by another person on this same thread. Now, I'm just down-right confused.
Old 2006.11.23, 08:28 PM   #58
Ninja
Mechanic
Ninja's Avatar
someone told you wrong. any time you decrease the distance at the pin without changing the tie rod, it will make your steering toe in. it may not be a full 1*, but im sure it is close. I have the 1* toe in bar on mine, so I couldnt tell you stock wise.
Old 2006.11.23, 09:47 PM   #59
fastXracer24
ferrari fanatic
I put in my two cents
fastXracer24 is offline   Reply With Quote
Old 2006.11.24, 12:02 AM   #60
locwan
locwan's Avatar
fastXracer24, nice car. However, are you sure you've mounted the tires correctly? they look like the tread is on backwards.
locwan is offline   Reply With Quote
Post Images of Your Overland Lexus86 Mini-Z Overland MV-01 81 2013.03.15 05:55 PM
Post images of your MR015 marc Mini-Z Racer MR-015 182 2013.01.04 11:26 PM
Post Images of Your Custom Transmitters! soulstice Transmitters, Receivers and Crystals 53 2012.02.02 05:11 AM
Post images of your Lit marc Mini-Z Lit ML-010 0 2007.03.04 09:36 PM
Post Images Of Your Track mikOll Tracks and GTGs 9 2006.06.14 08:08 PM
