Old 2008.03.11, 07:49 PM   #1
philophob
I broke my Pinion gear :(
Today I was fooling around and driving my Z on asphalts etc etc.
My ready-kit came with 3 extra pinion gears so I was putting them on and off.
6T was on originally and ran great with it.
There are 7,8,9T pinion gears (crappy plastic ones).
I tried to put on other 3 pinion gears but it wouldn't turn the wheels.
I found out that those extra 3 pinion gears do not fit with my diff gear oddly.
I am not sure why Kyosho ready-kit included 3 extra pinion gears that don't fit.
It seems like those pinion gears are bit too big and pushing out the diff gear against it.
Anyways, I was fooling around with Z and all of sudden, Z got slower and made grinding noise.
I turned it off and looked for the problem and bam! I see one of the teeth on the pinion gear is missing!
I guess it's made out of plastic and all but after just 3days of running it is gone.
Talk about stock component quality!
Now my questions coming.
I want to get a machine cut alloy type pinion gear and diff gear.
Is there like universal pinion and diff gear products?
I mean I find that with more teeth on the pinion gear, the size gets bigger and I have no space on my motor mount to make room for the bigger pinion for my diff gear. (Do I sound right? I am trying to describe what I've seen so if I am wrong please correct me.)
I looked at some MR02 products but I don't see such things for MR015.
Can I just use MR02 motor mount/pinion gear/diff gears for my MR015?
Plz recommend some good products to mod my Z~
Please excuse my noob-ness!
philophob is offline   Reply With Quote
Old 2008.03.11, 08:04 PM   #2
mk2kompressor
at the Bleeding Edge
mk2kompressor's Avatar
also supplied with the set is 3 different sets of motor spacers to allow you to use the 3 different pinions.
read the destructions
Team B.E.R.T
MR02/3 eating MA010
MR-03
HFAY S9 F1 Winner
Sinister V1
MRCG Prototype
MRCG 1.0
Bleeding Edge Racing UK
Old 2008.03.11, 11:41 PM   #3
philophob
I can't find my instruction book!
Oh well, it is probably in the original box the Z came with...
Got some reading to do!
Old 2008.03.12, 04:49 AM   #4
there are spacers for the pinion gears so that they properly mesh with the spur gear (the gear turning the rear axle)
thread to online manuals....
http://mini-zracer.com/forums/showthread.php?t=27785
Old 2008.03.12, 06:27 PM   #5
philophob
Found very useful diagrams and instructions on the manual, thanks to friends above.
Mini-Z is quite more sophisticately(?) designed/engineered than I anticipated.
I am enjoying it too much.
Old 2008.03.12, 08:58 PM   #6
AlloyENZO
You can get alloy pinions from Atomic as a set or singly. I had them but returned tham after I learned they were not necessary. Your situation may be different though.
AlloyENZO is offline   Reply With Quote
GPM .. they have many parts.. are they all available? bcuzau Mini-Z AWD MA-010, MA-015 5 2006.03.14 08:12 AM
How to change the play between Spur gear and pinion gear on F1 ? Bandie Mini-Z F1 MF-010, MF-015 0 2005.01.16 07:47 AM
Whats the Pinion Gear, Spur Gear relation? G'ZOX Setups 5 2004.02.16 01:19 AM
pinion and spur gear questions racerdx6 Parts and Hop-ups 4 2003.07.05 09:18 PM
differential and pinion gear upgrades RCPMini-z Beginner Questions 3 2003.06.02 01:55 AM
