Old 2012.11.28, 08:30 AM   #1
HammondCheese
MR-02 Board Compatibility
Yup, project MR-02 has definitely reached the point where it would have been easier buying an actual MR-02 body set to start with. It would have probably been cheaper and would have saved a lot of dumb questions.
I've just woken up the the difference in servos btw the 02 and 03. However, a number of sites (I'm looking at you Kenon and EGR) seem to list the MZ410 board as being an 02 compatible part. What (if anything ) do I need to convert? I've seen a Mini-Z Servo Motor (2WD) from RV-Project on EGR. Would it possibly be as simple as a switch to this (or would Atomic's AWD servo fit...and work...it looks vaguely similar...)?
Or am I about the have to invest in a MZ303 board too.
Thanks all.
HammondCheese is offline   Reply With Quote
Old 2012.11.28, 11:32 AM   #2
kryten
kryten's Avatar
If you want to use an 03 board in an 02 you will need to use the 02 servo motor. MZ410 has the 03 servo motor attached.
02 AM Board Trouble KA2AEV Beginner Questions 1 2011.07.10 12:58 PM
MA-010-MR-02 AD board set Conversion sciencemike Mini-Z AWD MA-010, MA-015 21 2009.08.16 02:09 PM
V2 Power Board TinRacers Atomic 1 2007.06.14 12:07 PM
IW-04 board in MZM bw762 Mini-Z Monster MM-01 0 2005.03.06 05:13 PM
MR-01/OL board with 5 cells miketre Mini-Z Science 4 2003.11.25 05:16 PM
