Go Back   Mini-ZRacer.com Forums > Tracks and GTGs
Old 2018.11.04, 06:13 PM   #1
MPG1959
RCP track, Smooth side up rough side up?
New to mini z's. I just picked up a RCP track and cars used, what side up do you run? and what tires?
MPG1959 is offline   Reply With Quote
Old 2018.11.04, 06:43 PM   #2
Qball41
Lots of variety on tires. I'm usually around 15 degrees rear, 20 degrees front.
In the track, we just formed a new group and we are racing on the smooth side.
Qball41 is offline   Reply With Quote
Old 2018.11.04, 07:11 PM   #3
Welcome... I actually haven't tried the smooth side yet... but for the rough side kyosho 30 front 20 rear.. if you find yourself traction rolling go for 40 fronts.. tire choice is about 80-90% of your set up... so choose wisely.. hope this helps...
Old 2018.11.04, 07:20 PM   #4
Smooth side is the way to go especially if you want reduced tire wear. But on either side be sure to stay away with any silicone based tires as they will destroy the racing surface. Once it gets into the surface it is virtually impossible to get it out.
Old 2018.11.04, 07:22 PM   #5
I race on rough and smooth at different venues. Kyosho 20 rear and 30 fronts works on both. Smooth side has a little more initial and overall mode more traction than the rough side. I raced on the rough floor many more years before trying the smooth, and prefer the smooth side since there is more consistency.
Old 2018.11.04, 07:59 PM   #6
MPG1959
So you say stay away from silicone tires, what brands to Run?
Old 2018.11.04, 08:00 PM   #7
MPG1959
Thanks for the input guys
Old 2018.11.04, 08:46 PM   #8
SuperFly
bitPimp
SuperFly's Avatar
I think PN is probably the most popular brand. They have two RCP formulations, in slick and treaded.
I usually use PN Racing Mini-Z KS-M Compound RCP Radial Rear Tire SOFT and PN Racing Mini-Z KS-M Compound RCP Slick Front Tire SUPER SOFT, but sometimes go with SOFT or MEDIUM up front, and sometimes SUPER SOFT in the rear.
I'm interested in trying the Marka tires next time they are in stock. I also use Kyosho tires, and their rating system is a little different. The Kyosho tires last longer than PN, and have a longer shelf life, IMO.
mini-z gallery
PDX Mini-Z
Old 2018.11.04, 09:11 PM   #9
MPG1959
Cool thanks
Old 2018.11.04, 09:32 PM   #10
Yes do not use silicone tires on rcp...
Anybody know if kyosho tires are silicone free?
Old 2018.11.05, 05:56 AM   #11
Tires from any manufacturer that are marked for carpet use are very likely to be silicone based. Personally I would not run anything but Kyosho rubber. It is more than adequately "sticky" for any application and affords the best batch to batch consistency as well as superior shelf life not to mention wear characteristics. You may need a more precise set up with Kyosho rubber but your car will remain consistent throughout a run and subsequent runs. You can get more "grip" out of other manufacturer's rubber but you will likely find that the car is not consistent from run to run or even throughout a single run based on ambient conditions especially humidity.
Old 2018.11.05, 02:39 PM   #12
I agree entirely with what Mleemor has posted. There is a smaller setup window mechanically, but there is also a wider window of operation. The Kyosho rubber is less temperature sensitive than other rubbers that I have used, and works just about everywhere.
If you are racing stock motor (70t/even 50t) then Kyosho rubber will give very good consistency within .3s of faster rubber. When you get into modified motors, then alternate rubber may be a better option. I generate wheelspin with modified power on Kyosho rubber. PN rubber can tame it, but I will go through one set of tires in a race day compared to Kyosho rubber that can last 5 race days or more depending on the power and surface traction.
Old 2018.11.05, 09:48 PM   #13
Thanks for the info...
Old 2018.11.07, 07:47 AM   #14
RCPMini-z
rcptracks.com
I would definitely go PN for tires. They make both RCP radial and slick tires for most applications and racing styles. I've used mostly the rough side in the past but am now favoring the smooth for reasons others have posted above. One quick tip, it is useful to take a very lightly dampened mop to the top surface of the smooth side of the tiles, once in the morning or once before you use the track. It helps to take the dust off the surface of the smooth side that has collected over night.
Old 2018.11.07, 09:00 AM   #15
Qball41
To help keep the track surface clean, we use a large roller made for pet hair clean up. Its basically like going over the whole track with a lint roller. Its nice because its about the size of a paint roller, and comes on a long shaft, so its quick and easy.
It removes the dust and fine dirt that seems to get tracked in over time.
HFAY - RCP track side? smooth or textured? briankstan How Fast Are You? Online Points Series 15 2016.05.20 03:19 PM
New RCP Track Tiles/Rails/Discs for the Mini-96, dNaNo, Mini-z and HPI 1/32 RCPMini-z Tracks and GTGs 33 2010.10.13 09:11 PM
Different coded / keyed Kyosho RCP and normal RCP? Ensonic RCP Tracks 10 2010.02.19 12:02 PM
RCP REleases New Super RC Speedway into the Toy Industry RCPMini-z RCP Tracks 10 2009.09.30 04:24 PM
RCP Tile Cut Pattern Variant RCPMini-z RCP Support Forum 0 2007.07.23 08:35 PM
