Old 2007.12.19, 07:48 PM   #1
Battery and Charger for Tamiya M-04L
i have the tamiya m-o4l xb volkswagen kit. i need simple and idiot proof battery and charger for this. any suggestions?
nothing fancy or performance oriented. just good run time and simple plug in to charge. my son has to be able to do this if this gives you an idea... could be a cheap wall charger for all i care.
Old 2007.12.20, 07:55 AM   #2
no one... i need to get something before x-mas.
Old 2007.12.20, 01:32 PM   #3
BobT
BobT's Avatar
I am not familiar with that chasis. What type battery/pack does it require?
Bob Tierney
BobT is offline   Reply With Quote
Old 2007.12.20, 01:41 PM   #4
cowboysir
A Duratrax Pirahna is about the simplest/cheap peak charger around..,you only have to set the program the once, plug it in and press the enter button to charge.
Packs are a dime a dozen if you're looking for value...I've seen tow or three for one sales on eBay.
my custom body album...
Old 2007.12.20, 02:30 PM   #5
1. do i assume all 6 cell stick packs use the same size cells?
2. is there a cheap wall charger? i have a Pirahna and it's not something i woudl give to an rc novice despite the easy setup. i need something that is as simple as plug it in and when the light chnges/goes off it's done. this will only be used casually for fun adn not very often.
Old 2007.12.21, 08:25 AM   #6
El Tigre
Try this, it looks simple and 2000mah should give you 15 or 20 mins on a Tamiya stock motor.
El Tigre is offline   Reply With Quote
Old 2007.12.21, 03:06 PM   #7
3200mah Trinity Pack $22
http://www3.omnimodels.com/cgi-bin/w...I=TRIC2080&P=0
DuraTrax Piranha DC Peak Charger NiCd/NiMH 12V $18
Fixed 4A charge rate
http://www3.omnimodels.com/cgi-bin/w...I=DTXP4002&P=7
edit: I had originally posted Tower links, but they didnt work, and I didnt want to go around the filters... Same products, same prices...
Could try the shack
http://www.radioshack.com/product/in...entPage=family
http://www.radioshack.com/product/in...ductId=2147160
Old 2007.12.21, 08:21 PM   #8
TheRinger
THATS HOW I ROLL
TheRinger's Avatar
As far as I can tell U need a 6 sub C cell stick pack. Emu pointed out a decent charger and radioshack also sells 6 sub C cell stick packs cheap. Or U can get a MRC superbrain 820 charger which is a plug in and forget it charger and a venom sub C cell stick pack.
Lacrosse BC-900 Alpha Power Battery Charger arch2b Batteries, Chargers and Dischargers 41 2007.10.24 06:25 PM
best battery charger for the $ steiner9 Batteries, Chargers and Dischargers 12 2007.02.20 04:46 PM
Squat battery charger Dark Horse Parts and Hop-ups 1 2003.11.15 11:28 AM
Battery charger suggestion ZAppy Miscellaneous Discussion 18 2002.01.28 02:43 PM
