2013.03.14, 08:53 AM
#46
of both Time and Space
My track is small, but its in my finished basement, so temps are fairly constant. Here's a picture!
2013.03.14, 08:55 AM
#47
Wow! It looks bigger in that picture
2013.03.14, 07:12 PM
#48
that reminds me very much of how i got our club started with my track in my basement
2013.03.14, 08:52 PM
#49
PN RacingTEAM Driver
Originally Posted by imxlr8ed
When we used to run slick side it always seemed like there was a ton more traction than the rough... I'm starting to think that track temperature has more effect on the smooth side's traction level than it does on the rough side.
back in 2007 before i went to run my first race @ kenon, i ran my track on the smooth side not many tires worked on that surface as i recall... the old kyosho radials and a few of the gpm tires
so far almost every tire that i have used has worked ok if not great... some have had far too much grip
as far as temperature affecting it more on the smooth side.... i dont think its more or less.... its different!
seems to me the rear is affected on the rough side and the front on the smooth side
2013.03.15, 07:37 AM
#50
Grant, if I go to a harder spring in the rear of my PN top shock, will that give me more off power steering? Now, when I let off the throttle before the end of the straight and then try to make the 180 degree turn, my car doesn't come around.
2013.03.15, 10:49 AM
#51
it will help ...u can also try softer in the front
2013.03.16, 05:55 AM
#52
Thanks! I went from Red to Orange on front and Blue to Green on top shock and it helped... But I need more! Can I do anything with side damper springs? Currently running shiney silver stock spring. Thanks for the help!
2013.03.17, 09:47 PM
#53
I got to drive on the smooth side today at my local track. Only thing I changed from my rough side setup was front tires and tplate. I think the setup changes are minimal and don't require much effort, at least for Inside Line Racing.
This side does feel different than the rough side, but it is not a huge difference.
2013.03.17, 10:37 PM
#54
the shiny silver springs are stiffer than red but softer than green
me personally i run the blue springs from the top shock set
(0) preload with a #4 g-10 t-plate
2013.03.17, 10:38 PM
#55
glad to hear! see you next weekend!
2013.03.18, 04:03 AM
#56
Did you not get the e-mail?
We did a club vote and have been shunned from the ILR community.
2013.03.18, 04:12 AM
#57
Thanks for info Grant! I needed to go up 1mm on rear offsets under Mosler to get it to turn. Now all is great.
I agree that the smooth side is more consistent, and has very good rear traction, but not so much front bite that traction roll is a problem (the rough side of my home track was really bad about this). So overall, I think I like the smooth side better But I need more time on it. Would also be curious to see consistency of smooth side between tracks as I hope to travel to a couple of PN regionals this year.
For kicks, I put my F1 car (that never ran worth a flip on any surface and was getting ready to be sold) down on the smooth side. Magic! Drives like a dream! Go figure!
2013.03.18, 06:41 AM
#58
For kicks, I put my F1 car down on the smooth side. Magic! Drives like a dream! Go figure!
the N.I.A. guys in Japan run their F1 series on the smooth side, here in the UK there is talk of running an F1 only meeting on the weekend of the Brit GP trying to replicate Silverstone in RCP and i am suggesting we run on the smooth side.
NoWayPedro#BTRR
2013.03.19, 05:08 PM
#59
More Impressions
