what parts are different between these kits? id like to order all the parts and see what a monster OL would look like (since all the parts they list on another site add up to like 80$)
Kyosho (#MM01) Servo Case Set For Monster USD$5.50
Kyosho (#MM02) Knuckle Arm & Tie Rod Set For Monster USD$8.50
Kyosho (#MM04) Chassis Small Parts Set For Monster USD$6.00
Kyosho (#MM07) Gear Box Set For Monster USD$7.90
Kyosho (#MM08) Suspension Arm Set For Monster USD$4.50
Kyosho (#MM10) Shaft Set For Monster USD$9.90
Kyosho (#MMF01R) Color Screw Set For Monster -Red USD$8.50
Kyosho (#MMH01) Wheel Set For Monster USD$8.50
Kyosho (#MMT01) Tire Set (V-Treck/2Pcs) For Monster USD$15.80
Kyosho (#MMW02) Stainless King Pin For Monster USD$6.50
Sub-Total:USD$81.60
are there any other parts that are different? are any of these unnessary (like the same as on an overland?) also there is no servo case listed or anything
that looks about right.....??? without seeing which each kit contains, it's hard to be certain.
the servo case is the first thing you have listed
is the rear gearbox set the main gear etc or the rear gearbox? either way you'll need both.
the susupension arm set, are these the thin black rods that use the ball screws or the thin flat plates on the bottom? either way you'll need both.
it would be much easier if i just openned the instruction manual for mine.....it's still in the box which is??? doh, i don't recall where a lift the box.
wha you can do it check the part numbers with the overland parts listed in the kyosho overland parts album in the part in use gallery to see if any of the parts have the same number, thus you wouldn't have to buy it.
one thing that is definitely not listed are axles, and steering knuckles
i like the look of my overland much more and if i could make it even more reliable without spending 180.00 (half that for parts im hoping) then great, also i love those rims/tires
