Old 2001.12.18, 12:30 AM   #1
Unistar
Send a message via AIM to Unistar
Roll Shock Set, Main Shock set + graphite H bar
Hey guys, hmm i got my roll shok set and main shok set and i installed them and also installed the h bar, well now that they are there it looks like the car is so stiff like if i press down on it with a finger the back doesnt even bend unless I do it hard, it seemed like when i had a factory plastic h bar and nothing else the car looked like it had a phat suspension which was ebnding and stuff, hmmmm? is it supposed to be like that
i am using graphite h bar the smallest one of 3
and medium stiffness springs in main shok set and roll shok set, ehh =(
if anybody needs a picture i'll take it
thanks!!!
Unistar is offline   Reply With Quote
Old 2001.12.18, 12:43 AM   #2
Russ
Super Moderator
Russ's Avatar
That sounds normal, one thing you can do is check how much preload is on your rear damper spring. The roll shock springs don't do much, if anything at all for the up/down action of the rear wheels, or at least my roll shock set doesn't...all they do is pivot with the up/down motion.
What makes your rear the stiffest are the fiber H plates. It sounds normal though.
Russ
Old 2001.12.18, 05:18 PM   #3
Mondo
Mini-Zedologist - Fear me
Mondo's Avatar
High Fibre diet
Agreed Russ,
I got the Kyosho carbon-fibre H-plate and even the softest one makes the rear as rigid as a convent girl on a first date
It made quite a difference!
Mondo
Old 2001.12.18, 06:51 PM   #4
Unistar
thanks guys, hmm maybe i need to put the original plastic one back? and use it with the suspension? what does everybody else uses? and what will be a next upgrade that I should get? i know ball diff set i think, but whats good after?
thanks!
Old 2001.12.18, 07:35 PM   #5
Russ
Super Moderator
Russ's Avatar
I loved my stock H bar, but they break quite easy I've found out, just like most everyone else!! hehe...
As for the next upgrade, I couldn't tell you which I would do, the XSpeed motor or Ball Diff. If your Z is fast enough for you, go for the differential. However, I would suggest having the ball diff before the XSpeed (although that's not the route I went )
Russ
Old 2001.12.18, 10:47 PM   #6
Unistar
i've read somewhere that x-speed doesn't give that much speed improvement and that there are other motors that are very powerfull..... any comment on that?
Old 2001.12.18, 11:33 PM   #7
mini-z
Administrator
mini-z's Avatar
Unistar, I would have to disagree with that, the X-Speed is a great motor all round. RE the H-bar, you may want to try the colored (non-CF) ones we have in the Shop, look for "TopCad Colored H-Plates (Soft, Medium, Hard) - 3 PCS" under "Suspension and Handling".
[FS] PN AWD sway bar set pchan0 Mini-Z Marketplace 2 2008.07.06 08:02 PM
Damper set vs sock plus rollshock vs roll shocks only Hammer0412 Setups 0 2005.02.16 01:45 AM
Just got the roll shock set! PorscheGuy964 Parts and Hop-ups 27 2002.01.11 06:53 AM
roll shock v. rear shock bbc5 Parts and Hop-ups 2 2001.12.14 03:04 PM
Roll Shock Set VS Side Shock Set - whats the difference? Unistar Parts and Hop-ups 4 2001.12.07 11:51 AM
