Old 2005.09.28, 01:27 AM   #1
official kyosho awd product description
finally in english.... hmm hope somebody didn't post this just yet...
more from:
http://www.kyosho.co.jp/web/product...iniz_awd-e.html
AWD plus 4-wheel independent suspension marks a new chapter in Mini-Z history!
If there is a real AWD vehicle out there, you can expect it to appear as a Mini-Z AWD. Of course, the Mini-Z AWD (All Wheel Drive) chassis maintains its high performance and sophisticated technology, as well as the incredible attention to detail. The Mini-Z also manages to achieve its shaft-driven AWD system in its minimal size with a precision king-pin strut system 4-wheel independent suspension. In addition, the high efficiency drive system features a specially shaped crown gear and pinion gear in the newly designed diff gear unit. The result is a level of resistance through the drive train about the same as existing 2WD versions to produce true racing machine performance. And the focus on weight throughout means the AWD is not much heavier than the 2WD version. However, the AWD features a high-power speed control amp with 30% more capacity than the existing 2WD chassis to bring out the best performance from the new chassis. You won't believe that so much power and performance can come from a machine so small! And the level of detail is as high as ever with a variety of body styles that match the 65mm minimum width of the chassis beautifully. The design also allows increased freedom in setting adjustments such as toe angles with optional parts. If your hungry for the excitement of high performance racing technology, the new "AWD chassis" puts you right at the front of the starting grid in the world of micro racing!
ReadySet Contents
Factory assembled chassis with installed R/C Unit
Painted plastic body complete with markings
Wheel-type transmitter
Pinion Gear 4-types, Spur Gear 3-types (combines for 3 different
wheelbase settings)
Chassis height adjustment collars
Pinion Gear Tool
Spare Nuts
Wheel Wrench
* AA-sized batteries X 8 for transmitter, AAA-sized batteries (alkaline or Ni-MH) X 4 for chassis are sold separately
Chassis Set Contents
Assembled chassis with installed R/C unit
Pinion Gears: 4 varieties, Spur Gears: 3 varieties
(3 different wheelbase setting combinations possible - total 6 gears)
6 types of wheel setting combinations with different offset and widths
(total 14 wheels included)
8.5mm width tires x 4, 11mm width tires x 2
Ball Bearings
Chassis Height Adjustment Collars
Wheel Wrench
* Body, Transmitter, and AAA-sized batteries X 4 (alkaline or Ni-MH) are sold separately.
* 4 different sizes of offset wheels included -total of 10 wheels (0 offset: 4 wheels, +1.5, +2.5 & +3.5mm : 2 each). In addition, two offset sizes of 11mm wheels (offset 0 & +1mm X 2 wheels each) are included (in the chassis set).
Factory finished body is complete with coloring and decals.
Drive energy is transferred to the ground through high strength resin universal swing shafts with metal core.
Equipped with 4 precision ball bearings for high drive efficiency.
Includes 4 types of pinion gear and 3 types of spur gear for a wide range of gear ratio settings.
Includes collars that enable chassis height to be adjusted to low down setting.
Bump stop fitted to front to regulate suspension stroke and prevent tire and body contact.
Micro-edge precision finish to 1/100mm.
Easy-access diff unit can be removed/installed by simply loosening 4 screws on the front and 6 on the rear.
AWD lets you enjoy a controlled driving posture as you drift through turns.
Only 5g heavier than the MR-02 chassis series but features AWD and 4-wheel independent suspension.
Chassis design allows minimum width of 65mm so most body styles for MR-01 and MR-015 chassis can be used.
Wheelbase can be easily adjusted to the Mini-Z Racer M and L sizes so you can use those exquisite Mini-Z bodies you already own. (Some body shapes are not able to be used).
Regarding body fitting, the Mini-Z AWD shares the same dimensions as the MR-015. Therefore, the bodies that fit the MR-01 and MR-015 and their M and L-sized wheelbases can be used on the AWD.
The Mini-Z AWD uses specially designed wheels. These cannot be interchanged with the Mini-Z Racer wheels. Please choose from the wheels included in the AWD chassis set.
The wheels currently available with Auto Scale Collection are not suitable for the Mini-Z AWD. Please choose from the wheels included in the AWD chassis set.
The wiring on the motor used in the Mini-Z AWD is different to motors used in the current Mini-Z Racer Series up until now. Please use the AWD motor set.
Old 2005.09.28, 02:22 AM   #2
HammerZ
Master of Thrash
HammerZ's Avatar
I thought that there are just two wheelbase settings M 90mm or L 94mm? And it also look's like the readyset don't have the bearings or extra wheels the chassis set has, right?
Old 2005.09.28, 08:41 AM   #3
good points... lets all hope that the missing items have just been lost in translation...
i think wheelbase is m 90 and l 94... since most of the autoscale bodies came in those settings... but in spite this, they did mention that not all bodies will be able to fit the awd chassis... i did see in a picture that there was a vitz body on the chassis, alongside the evo f2f chassis...
the suspense is killing me... aurgh!!!!
Old 2005.09.28, 09:06 AM   #4
Ken Mifune
2-Z or not 2-Z...
Ken Mifune's Avatar
It sounds like three wheel base settings. The spur gear is part of the transformation, weird.
-Kenichi's Album-
Old 2005.09.28, 10:37 AM   #5
pchan0
Team ShoBoi
pchan0's Avatar
Send a message via ICQ to pchan0 Send a message via MSN to pchan0
Herman is right, just two settings.
pchan0 is offline   Reply With Quote
Old 2005.09.28, 10:51 AM   #6
Ken Mifune
2-Z or not 2-Z...
Ken Mifune's Avatar
Good catch on the picture. I was just going by the contents description. It'll be nice to see(own) one in person.
ReadySet Contents
Pinion Gear 4-types, Spur Gear 3-types (combines for 3 different wheelbase settings)
Pinion Gear Tool
Spare Nuts
Wheel Wrench
Ball Bearings
Wheel Wrench
-Kenichi's Album-
Old 2005.09.28, 10:53 PM   #7
davkin
Master of My Mini Domain
davkin's Avatar
King pins = sophisticated technology? I don't think so, and no matter what they do it isn't going to be precision for more than a lap or two. AWD is cool, but this suspension is a big disappointment, I'd rather have an H plate suspension that this crap.
David
Salt Lake Mini-Z
Old 2005.09.29, 02:25 PM   #8
akura2
PROFESSOR TRUTH JIMMY ICE
akura2's Avatar
Send a message via Skype™ to akura2
Kingpins and springs were always a disappointment to me with the mini-Zs in general... never smooth enough out of the box to actually work.... and now they are on all four corners.... bleh... I prefer A-arms
akura2 is offline   Reply With Quote
Old 2005.09.29, 02:27 PM   #9
akura2
akura2's Avatar
Why do they keep removing the "edit" button?....
anyway.. I was going to say, I will just have to wait for iHobby to see them in person before I make a judgement
Old 2005.09.29, 03:20 PM   #10
Random Insanity
Your G.F.'s best friend
Random Insanity's Avatar
Looks good but I want to see an AWD OL!
My R/C'sRC10DS, T-Maxx, Mini-T, X-Mod, Schumacher Mission CF Drifter
Yeah, im back!
Random Insanity is offline   Reply With Quote
Old 2005.09.29, 04:17 PM   #11
Aaronnn
(TITANIUM)
i look foward in getting one of these.....
however i dont see why they cannot use wider rear wheels...?
Aaronnn is offline   Reply With Quote
Old 2005.09.29, 06:13 PM   #12
Ken Mifune
2-Z or not 2-Z...
Ken Mifune's Avatar
Originally Posted by akura2
Kingpins and springs were always a disappointment...
Yes they are, but the movement of the suspension for a racer at this scale is so minute, especially for those that lower the chassis. Although also minute, king pins keep the unsprung weight down. Functionally it makes sense but A-arms are definitely more sexy and any body that has raced a Mini-X knows that it works well. We'll just have wait and see.
-Kenichi's Album-
Old 2005.09.30, 03:22 AM   #13
from the site...
0 offset - 4
+1.5 mm - 2
+2.5 mm - 2
+3.5 mm - 2
0 offset - 2 (11mm - wide wheels)
+1mm - 2 (11mm - wide wheels)
hmmm i count 14 wheels??? lost in translation again???
or 10 wheels in the rtr, 14 wheels in the chassis set???
but nevertheless... a bunch of wheels with different offsets... mean you can put on a variety of bodies on the chassis... i've seen some awd pics with wide rears... and a vitz on the awd chassis...
Old 2005.09.30, 06:30 AM   #14
byebye
byebye's Avatar
These come with the sets or are options? I read options earlier but it seems like your saying in the set? Would make sense to be in the set.
-Byebye
Old 2005.09.30, 12:10 PM   #15
Aaronnn
(TITANIUM)
that good news about the wheels.....
official kyosho optional parts list herman Parts and Hop-ups 7 2008.05.21 12:56 PM
official kyosho parts list herman Parts and Hop-ups 3 2003.03.17 05:09 AM
kyosho official parts list herman Setups 3 2003.01.28 12:01 AM
official kyosho parts list (6 pages) herman Parts and Hop-ups 9 2003.01.24 12:41 AM
