Old 2008.04.23, 04:31 PM   #1
Davey G
Need a mini z Painted????
Davey G's Avatar
Dying Mini Z Parts
Here is a question that I dont think has ever been asked. Are the mini z parts dyeble? I know most plastics are but some shrink. LOL
I just purchased a Mini z nascar and hate the red parts and am not willing to paint them. I would like to Dye them black, has anyone done this before? If not I WILL be the guinnea pig and try it on some older parts I have laying around.
Thanks for looking....
Dave Graboski
DG Designs
Old 2008.04.23, 05:16 PM   #2
TALLGEESE
Dreamcrusher
TALLGEESE's Avatar
Davey, just this past weekend I used some RIT liquid dye that I got at Wal-Mart to dye the Kyosho Mini-Z oil filled rear shock dark navy blue instead of the original yellow color.. It turned out extremely well, no warping or shrinkage of the parts.. Even the tiny C-shaped shock pre-load spacers turned out O.K.
I've personally never tried dyeing anything the size of the top cover for an MR-015 though.. Since it's most likely the same type of plastic Kyosho uses to make the rear shock you should be alright.. As long as you don't leave the parts you're trying to dye in hot/boiling water for too long you should be alright.. When I dyed the rear shock, it only took about a minute to fully dye the part.. Hope this helps...
TALLGEESE is offline   Reply With Quote
Old 2008.04.23, 06:47 PM   #3
Davey G
Davey G's Avatar
I have had success and some disappointment depending on the plastic. I have had nothing but success with the nylon'y white plastic taking color and not deforming. I tried to die the plastic chassis of my Kyosho HOR motorcycle and it completely melted. I will let you know how the red parts come out. Thanks!!!
Dave Graboski
DG Designs
Old 2008.04.23, 08:57 PM   #4
Ninja
Mechanic
Ninja's Avatar
now you guys got me thinking......................
instead of painting a white body............
you get where this is going
I will have to try that when I get the funds
Real Racers Do It Sideways.
Old 2008.04.23, 09:14 PM   #5
Roketmini
The C is Missing.
Roketmini's Avatar
Send a message via AIM to Roketmini
Ninja-I've been on the same train. Dye a body gray or silver, so when the paint comes off from hitting something it looks like metal underneath instead of white plastic =D
Support your LHS
Roketmini is offline   Reply With Quote
Old 2008.04.24, 12:09 AM   #6
marc
Honda Insight Racer!
How would you dye silver? I have not seen Rit dye available in silver and if so I'd tend to think it would turn out grey. Sound's like a good idea. Question is, how far into the plastic will the pigment go? Will you see it in all the crevesis, inside of the body and all those nook's and crannies? How through will dyeing the plastic be? Another question is, how thick a layer will the die be?
Old 2008.04.24, 12:27 AM   #7
I have seen one person warp a white body with dye. Make sure that the water is not very hot. I have also seen it come out pretty well, where the water was not very hot.
Dave, I havent seen anyone dye the top plate. I should have a spare top cover, if you need
Old 2008.04.24, 12:32 AM   #8
Ninja
Mechanic
Ninja's Avatar
for a thin body I think just hot tap water will be warm enough to soften it to the point to accept the dye. You could always soak it overnight if needed to allow the dye to soak in properly.
Old 2008.04.24, 01:14 AM   #9
TALLGEESE
Dreamcrusher
TALLGEESE's Avatar
When I dye parts I like to use really hot water, just below boiling temperature.. I've tried doing it with slightly cooler water with a little more dye mixed in and got pretty good results as well, it just took a little longer..
Old 2008.04.24, 01:17 AM   #10
Have you dyed an unpainted body? Just wondering what the results were if you did.
Any colored chassis parts that I have seen were painted... It would be nice if Kyosho were to make the small parts set in white... for easy painting or dying.
Old 2008.04.24, 02:08 AM   #11
TALLGEESE
Dreamcrusher
TALLGEESE's Avatar
EMU, I've never tried dyeing an unpainted body before, I always wanted to try it though.. As far as painting the top case and small parts, I could see doing that on a display/show chassis.. I don't know if I'd do it to a car I planned on racing and maintaining a lot, too easy to scratch or chip the paint..
Old 2008.04.24, 02:23 AM   #12
I think thats why Dave wants to dye it
Old 2008.04.24, 09:32 AM   #13
danieluki
Any example picture of dyed piece...?
Just to see how good is the final superficial finish...
danieluki is offline   Reply With Quote
Old 2008.04.24, 04:32 PM   #14
stuZ
mini-z muckraker
stuZ's Avatar
Back in my Overland obsessed days I tried to dye a few OL chassis' black.
I used very low heat, but I guess not low enough. I warped all of them.
However, upon reading these posts, if you were to use very warm tap water and time, you'd probably not warp anything and get good results.
stuZ is offline   Reply With Quote
tamiya 1/32 mini 4wd parts and cars wanted! Simoncino Off-Topic 7 2006.05.28 03:19 PM
Tamiya 1/32 Mini 4wd Parts And Cars Wanted! Turbo Dash Motor Simoncino Miscellaneous Discussion 1 2006.05.26 11:27 AM
parts comparison with Mini Z racers nivolaco Mini-Z Overland MV-01 2 2003.12.09 12:01 PM
Old parts harrybullitt Mini-Z Overland MV-01 0 2003.11.13 11:16 PM
