Old 2008.09.28, 12:02 AM   #1
benmlee
PN Front Caster Tower Bar Version 2
Version 2 of the PN tower bar just came out. This version is meant to be used with the PN front sway bar. This tower bar is higher than the stock suspension arm by .5mm to compensate for the bar end cups used in the sway bar, which has a .5mm thickness. That way, ride height and suspension travel stays the same. Bar has cut outs and scallops features to reduce weight to a minimum when compared with version 1.
On Friday, I tried the tower bar along with sway bar using the softer of the two sway bar installed. Took a little time to straighten out the sway bar so it lay flat on the table. Due to manufacturing tolerance, the sway bar out of the package is not perfectly flat. After that, the car handled better than it ever had. The car corners flat and sharp like is on rails.
Old 2008.09.28, 02:53 AM   #2
saiyan
BooYa!!
saiyan's Avatar
The extra bit of handling is from the stiffer set up now with the added alloy. This allows the rest of the suspension to do its job with out the weaker flexing plastic to muddle it up. It's like adding a tower bar.
My minizracer gallery:saiyan's paddock
Local Club Website: www mini-az.com
Kamehamehaaaaa!!!!!! Rallye racers are the originators of drift Speedchannel on-line rocks!!
saiyan is offline   Reply With Quote
Alloy front knucles and steering bar Bayarre Parts and Hop-ups 2 2002.06.22 09:37 AM
Front Stabilizer Alteration Draconious Mini-Z Science 6 2002.02.05 12:44 PM
Front to rear wheel balance under power radial1 Mini-Z F1 MF-010, MF-015 2 2002.02.02 03:06 PM
Stock Front Sway Bar Modification DAMZer Setups 2 2002.01.26 04:17 PM
Front Stablizer/antisway/antiroll bar thing ApacheXMD Parts and Hop-ups 23 2001.11.21 11:41 AM
