Old 2002.07.07, 07:44 PM   #1
Crash Rehven
Dust Collector
Crash Rehven's Avatar
My car, my antenna, and my new camera
Got a new digital camera, so I can finally post some pictures... I'm keeping them small... I've only got dial-up
This is my new antenna setup. makes for nice display since the antenna is removable.
Wall?... What Wall?...
Crash Rehven is offline   Reply With Quote
Old 2002.07.07, 07:46 PM   #2
Crash Rehven
Dust Collector
ok without the body... and close up.
Old 2002.07.07, 07:49 PM   #3
Crash Rehven
Dust Collector
and one of my experimental antennas... (I had a little inspiration from draconious's website!)
this antenna has about the same range as the stock one
Old 2002.07.07, 07:51 PM   #4
Crash Rehven
Dust Collector
and one last one (for now)
an attempt to make the antenna less obvious.
By the way... is there a way to attach multiple pictures to a post... so I don't have to put them up one by one?... anyhow...
Old 2002.07.07, 09:30 PM   #5
maxmo
Mini-Z Driver
maxmo's Avatar
Just like what your title said you are the ANTENNA Bender! Cool, keep up the good work!!
Manual Labor?? What's that?? I don't do Manual Labor!
maxmo is offline   Reply With Quote
Old 2002.07.09, 12:19 AM   #6
Crash Rehven
Dust Collector
Here's a couple more pics of my car. and the spare bodies I got... I knew I'd mess up my first body so I bot an extra so I wouldn't feel so bad about wrecking it.
Old 2002.07.09, 12:21 AM   #7
Crash Rehven
Dust Collector
Here's the underside of my car... the secret to my superb handling!
(nya nya... my car's worth $0.25 more than yours)
Old 2002.07.09, 12:23 AM   #8
Crash Rehven
Dust Collector
I bot some shiny roll shocks and I realized that they weren't made for the short wheelbase... so, I had to improvise... an old costco card.
Old 2002.07.09, 01:02 AM   #9
Crash Rehven
Dust Collector
My car: 1977 Monte Carlo Lancia Stratos
My spare bodies (autoscale):
1977 Monte Carlo Lancia Stratos (my sit on shelf extra)
1978 Sanremo Lancia Stratos
my hop-ups (on car):
Plastic Bumper (?topcad... I think)
Topcad Alloy front knuckles (Blue)
Topcad rollshocks (blue)
GPM Steel Kingpins
GPM Soft steel H-bars
GPM Alloy lock nuts
GPM Alloy Heatsink Motor Mount (gold)
GPM Alloy Motor Mount Cap (gold)
GPM Alloy Heatsink Battery mount (gunmetal)
GPM Alloy Steering Plate 0 deg (gold)
Kyosho Ball bearing set
Kyosho X-speed Motor
Kyosho rear Damper
Kyosho front suspension spring set
Team Homies Aluminum Bulkhead (purple)
****** Alloy pinion set
Some Differential (I think it's a GPM??) (purple)
GPM Alloy Servo gears
Squat wide foams
Kyosho 40 deg Front tires
Hunk of foam (helps with my front suspension -thanks Drac!)
Custom Antenna mount (by me!)
Hop-ups (just laying around...):
A whole pile of tires (some used some not)
A couple sets of front and rear aluminum rims (none match... I don't know why)
Kyosho delrin servo gear set (2 & 3 gear... #1 broke)
Spare Topcad motor mount (just in case...)
about a dozen custom antennas of various shapes and lengths
Ummm... I think that's it. or so... enough?
Old 2002.07.09, 01:30 AM   #10
mini-z
Administrator
mini-z's Avatar
Nice! From the look of that body, "Wall?... What Wall?..." isn't just a sig, it's a way of life!
mini-z is offline   Reply With Quote
Old 2002.07.09, 08:59 PM   #11
Crash Rehven
Dust Collector
... you should have seen the other guy...
Yeah... That "learning to drive" part was harsh. My last RC was a Hornet.... in the early '80s... All I knew how to do was do jumps off the curbs and drive in sandy lots!
a bad suspension and a tendancy to roll over helped my paint job a bit too! Now my car sticks to the ground so much I can't roll it if I tried!
Maybe it's time to put a slick new paint job on my old body!
Old 2002.07.15, 05:31 PM   #12
Z-Guy
Mini-Z Novice
Z-Guy's Avatar
Arrow
Hey Crash Rehven, could you tell me how each one of those anteanas compared to the stock ones?
Z-Guy
Z-Guy is offline   Reply With Quote
Old 2002.07.17, 02:30 AM   #13
Crash Rehven
Dust Collector
Ok.... My First replacement antenna (not pictured) was identical to the stock one except for the length (and it's a little bit thicker because I use 20 gauge galvanized wire... i think the stock one is 18 gauge wire). The antennae was about a foot and a half long. That one doubled my range... I never fully found out the range because I ran out of parking lot, but My friend and I drove it more than 40 to 50 Yards away! (about half a football field away.)
unfortunately, there was a drawback to the superlong antenna... it caused handling problems because of it's drag and weight. turns became tricky with the tall antenna waving itself around.
The spiral antenna and spoiler antenna (pictures above) have a similar range to the stock antenna... maybe a little less. around 20 yards or so
These antennas were the reason I needed to make the antenna mount...
most of my current antennas are not odd shaped and get slightly better than normal reception. I'll take some pictures and post them tomorrow with more descriptions...
Old 2002.07.17, 09:51 PM   #14
Z-Guy
Mini-Z Novice
Z-Guy's Avatar
Arrow
Did that twirly thing that holds the anteana(pic 2) make any difference?
Z-Guy
Old 2002.07.17, 11:07 PM   #15
Strider-
Strider-'s Avatar
Crash are those roll shocks by Topcad?
Strider- is offline   Reply With Quote
