Go Back   Mini-ZRacer.com Forums > Mini-Z Marketplace
Old 2012.03.01, 11:23 PM   #1
Ricochet
Ricochet's Avatar
SOLD: Ultimate MR03 RTR competition package MR-03 Kyosho
1. Name - Adam
2. Location - Rochester, NY
3. Contact – ajbenfante@yahoo.com
4. Description - See below
5. Price - $600 shipped CONUS (all others additional charge)
I have been racing indoor electric RC for almost 3 years. March 2010 a friend got me into Mini-Z’s at the time the MR03 was being introduced to the public. I raced occasionaly on weekends and if I had to guess, this car has about 40 races total on the stock chassis and even less on the upgraded parts/motor/batteries...etc. This has only been adult owned and driven. Maintained extremely well and always cleaned after each use with air copmpressor and soft cloth. I was very meticulous about re-greasing the differential every month, lubing the disc damper, kingpins and motor pinion before each race event. I hand polished the kingpins and upper steel suspension arm rods to obtain an extremely smooth and fluid-like front suspension. I also replaced the stock FET’s (4) with some high-end Fairchild 4562 FET’s. I choose not to stack the FET’s as the motor/pinion combo I am using (Atomic Stock R/Delrin Pinion 8T or 9T) is stupid fast and did not need additional FET’s to gain performance. I race with other friends who also own and maintain upgraded MR03’s and I can attest that my car is the most consistent with lap times and performance. Throughout my racing I purchased parts that are shown in the pics and listed below. Most parts were used very little as I attempted to fine tune the Mini-Z to my racing style which meant some parts only saw a few laps before I replaced them with other parts to "dial-in" on my driving style preferences. I can assure the next owner that this MR03 is race ready and setup like the pros for whatever track you can throw at it. With the wide array of parts that come with the sale you will be able to fine tune this MR03 to your driving style without spending another dime as I have almost every necessary upgrade option currently available. To top it off I have a custom made carry case for the MR03, parts and transmitter. Arrive in style to your next event and turn some heads. I am selling because I no longer have time to meet at the indoor track on the weekends with my racing friends. I am a new proud parent and to pull myself away from my newborn son for racing is not something I like to do. Rather than allow this RTR package to collect dust I have decided to sell it.
Stock:
MR03 Chassis set - $150
Upgrades (installed on RTR chassis):
KO Propo EX-1 UR transmitter with Mini-Z 2.4G module - $225
Atomic MR03 shielded bearing set (complete chassis) - $16
Atomic Stock R Evolution motor blueprinted by Reflex Racing - $42
PN Racing machine cut Delrin Pro Pinion (10T) - $5
4x Fairchild 4562 FET (replaced stock FET’s) - $14
Kyosho Ferrari F430 autoscale body (94mm yellow) - $30
PN Racing RCP Parada rear tire 6 deg - $4
PN Racing RCP Slick front tire 20 deg - $4
R1 Wurks 990HV AAA batteries (5 sets of 4) - $50
PN Racing MR03 stainless steel upper arm pin (handpolished) - $4
PN Racing MR03 stainless steel long kingpin (handpolished) - $4
PN Racing MR03 color shim set for kingpin - $5
Kyosho MR03 Hard fluorine coat 4.7mm ball - $9
PN Racing MR03 aluminum front spring holder (wide) - $8
PN Racing MR03 aluminum low down knuckle (set) - $19
PN Racing MR03 aluminum caster upper arm (0 camber) - $29
PN Racing MR03 aluminum toe-in tie rod (-0.5) - $9
PN Racing Multi-length graphite disc damper set - $23
PN Racing aluminum 94-98mm MM LG Motor mount V2 - $33
PN Racing V2 ceramic ball differential set - $30
PN Racing Ultra-light 1.29g ball differential shaft - $13
PN Racing MR03 High clamp force aluminum T-plate mount - $10
PN Racing MR03 carbon fiber T-plate (#3) - $6
PN Racing alloy 2mm wheel lock nuts (black) - $4
Atomic MR03 Titanium screw set - $10
Spare parts (gently used unless otherwise stated):
Kyosho McLaren autoscale body (98mm silver) - $30
New Kyosho MR03 servo gear set - $6
PN Racing 70T motor blueprinted by Reflex Racing - $25
New PN Racing RCP Parada rear tire 6 deg (1 pair)- $4
PN Racing RCP Slick rear tire 6 deg (1 pair) - $4
New PN Racing RCP Slick front tire 20 deg (3 pair)- $12
New PN Racing Carpet Slick front tire 18 deg (1 pair)- $4
New PN Racing RCP Slick front tire 15 deg (2 pair)- $8
New PN Racing Radial front tire 8 deg (1 pair)- $4
PN Racing machine cut Delrin Pro Pinion (9T) - $5
PN Racing MR03 aluminum toe-in tie rod (+0.5) - $9
PN Racing MR03 aluminum toe-in tie rod (+1.0) - $9
PN Racing MR03 carbon fiber T-plate (#4) - $6
Kyosho Mini-Z potentiometer (steering) - $7
PN Racing machine cut Delrin 20mm wheel rear (+1 offset) - $8
PN Racing machine cut Delrin 20mm wheel rear (+3 offset) - $8
PN Racing machine cut Delrin 20mm wheel front (+1 offset) - $7
PN Racing machine cut Delrin 20mm wheel front (+0 offset) - $7
PN Racing Disk damper screw washer - $5
PN Racing Mini-Z center shock spring set - $6
PN Racing Mini-Z front suspension spring set - $7
PN Racing Mini-Z low-down front suspension spring set - $7
PN Racing Mini-Z dual spring center shock set - $12
Lube, Oil, Adhesives and Misc:
Kyosho fluorine king pin oil - $13
PN Racing double side rim/tire tape (front + rear) - $4
Kyosho #15000 Differential grease (15g) - $11
Kyosho Silicone oil #500 (40cc) - $10
PN Racing Mini car foam stand (black) - $3
Atomic Super flex 18 gauge wire (black + red) - $6
Harbor Freight hard case with foam insert - $30
Total = $1033 not including shipping on approx. 15 different orders placed at:
kenonhobby.com
atomicmods.com
reflexracing.net
shop.tinyrc.com
ultimatehobbies.com
store.hkshobby.com
rcatomic.com
All prices are based on the above websites.
Youtube video of me racing in early June 2010 (watch the yellow car).
http://www.youtube.com/watch?v=8CrMjq8cuOI
I understand I have zero trader feedback here but I am also an avid RC heli pilot/builder with extensive feedback on the following websites under the user name (Adroc3905). I was unable to select this same user name for the forum. Please search these websites for my trader feedback concerning RC helicopters:
rcgroups.com
helifreak.com
runryder.com
*******om
Buy with confidence. Adult owned, driven and cared for.
More pics
http://www.rcgroups.com/forums/showthread.php?t=1037058
*******PLEASE NOTE********
*Preferred contact method is email (ajbenfante@yahoo.com)
*Serious buyers only
*All stock MR03 chassis parts that have been upgraded are included
*Package includes one RTR chassis and two bodies (94mm + 98mm)
*Not interested in trades of any type
Ricochet is offline   Reply With Quote
WTB silver and gold F40 Kyosho RTR Sets Sviny Miscellaneous Discussion 0 2006.04.06 04:09 AM
The Ultimate MR-02 Chezedog Mini-Z Racer MR-02 60 2005.05.15 06:24 PM
