Old 2015.02.08, 06:46 PM   #1
Jshwaa
Jshwaa's Avatar
The MR-03S Transceiver Module
FYI...
The lower-left IC labeled 'A7105' is the transceiver module (receiver) for the mini-z.
Here is the datasheet on that part should you have any receiver related issues/questions or ideas for modifications.
http://www.avantcom.com.tw/AVANTCOM/...SOLVE/18_3.pdf
Old 2015.02.08, 09:57 PM   #2
Solo1
Old nut
wow 89 pages now if it only made sense to me! lol would it be possible to change that chip with 1 from a receiver for another radio and have it work or would you have to change the part with the white stuff too?
Solo1 is offline   Reply With Quote
Old 2015.02.08, 10:09 PM   #3
Jshwaa
Jshwaa's Avatar
Not too sure, but i don't see why it wouldn't work if you really had to. That part seems like it's more of a microcontroller that can be programmed, but has some radio frequency components in it as well. I've been trying to tap into the SPI protocol between it and the 8815 chip, but all my data analyzer picks up is garbage. Without knowing the exact protocol they are using, it's all cryptic and full of errors.
On page 81, they provided an example of the circuit that this chip needs to operate. This is a freebie for us as it pertains to the mini-z schematic, as I'm sure that most of this circuit resembles the actual mini-z layout.
FS: 2 Fetted 03's, Radio, Module Parts.... Check inside PadrinoNY Mini-Z Marketplace 1 2011.08.09 09:02 PM
FS 2.4 Module AM module And Some Auto Scales MiamizFinest Mini-Z Marketplace 0 2011.03.21 10:01 PM
New module that only fits the ex-10 Eurus tbar1981 Transmitters, Receivers and Crystals 3 2010.04.30 04:11 AM
Signal problem with my RF901-SM Mini-Z 2.4ghz module for Helios Felix2010 KO PROPO 6 2008.12.19 12:02 PM
Preliminary testing and thoughts for using 2.4G module with EX1UR + 2.4G AWD Aurora 2.4GHz ASF System (Auto Selected Frequency) 9 2008.05.26 02:51 AM
