Go Back   Mini-ZRacer.com Forums > Tracks and GTGs
Old 2018.11.07, 10:19 PM   #16
MPG1959
Where do you get those rollers at?
MPG1959 is offline   Reply With Quote
Old 2018.11.08, 05:55 AM   #17
Qball41
Actually, I got it at petsmart.
https://www.petsmart.com/dog/cleanin...ler-39970.html
its a pet cleaning supply that many pet or department stores will have.
Qball41 is offline   Reply With Quote
Old 2018.11.08, 11:14 AM   #18
Originally Posted by RCPMini-z View Post
I would definitely go PN for tires. They make both RCP radial and slick tires for most applications and racing styles. I've used mostly the rough side in the past but am now favoring the smooth for reasons others have posted above. One quick tip, it is useful to take a very lightly dampened mop to the top surface of the smooth side of the tiles, once in the morning or once before you use the track. It helps to take the dust off the surface of the smooth side that has collected over night.
Personally I would avoid any tire offering from PN at all costs. Historically the issues with them dissolving in the unopened bags, the inconsistency from batch to batch as well as bag to bag within a batch, the less than ideal wear characteristics coupled with the handling changes that can be experienced during a single run would keep me from even considering them. They can make you go fast but the side effects aren't worth it to me. I prefer a chassis dependent set up as opposed to a tire dependent set up that will change during the course of a run based on tire temp or debris accumulation caused by an overheating tire.
These comments are likely to bring out some haters that believe that the PN flavor of Kool-Aid is the only one out there. Don't get me wrong. I feel that PN makes some of the best kibble and bits out there but I just don't feel that way about their tires. Just don't get caught in the "if you want to be the fastest you must have this or that" Don't eat it Elmer, it's caca.
HFAY - RCP track side? smooth or textured? briankstan How Fast Are You? Online Points Series 15 2016.05.20 03:19 PM
New RCP Track Tiles/Rails/Discs for the Mini-96, dNaNo, Mini-z and HPI 1/32 RCPMini-z Tracks and GTGs 33 2010.10.13 09:11 PM
Different coded / keyed Kyosho RCP and normal RCP? Ensonic RCP Tracks 10 2010.02.19 12:02 PM
RCP REleases New Super RC Speedway into the Toy Industry RCPMini-z RCP Tracks 10 2009.09.30 04:24 PM
RCP Tile Cut Pattern Variant RCPMini-z RCP Support Forum 0 2007.07.23 08:35 PM
