Old 2011.02.05, 11:00 PM   #1
Dr. Kustom
Dr. Kustom's Avatar
Send a message via MSN to Dr. Kustom
Brown Yota "clone"
After sold my LC80, I decided that I wanted a new rig. I came across this rare Aoshima Hilux model kit. It was very pricey, but I've yet seen this model kit mounted on the Losi Micro Crawler yet, so thought I should give it a try.
Starting with this stock LMC, the stock wheelbase line up with the body pretty well.
GSR / Atomic
Dr. Kustom is offline   Reply With Quote
Old 2011.02.07, 07:42 PM   #2
Beatles
bro i think you should keep it lowered.
Beatles is offline   Reply With Quote
Old 2011.02.07, 10:04 PM   #3
monkey19
monkey19's Avatar
Send a message via Yahoo to monkey19
Sweet! Can't wait to see how this comes out....
Joe
"remember you are a genius until you open your mouth"- Stuart Wilde
monkey19 is offline   Reply With Quote
Old 2011.02.07, 10:05 PM   #4
Dr. Kustom
Dr. Kustom's Avatar
I like it lifted better.
Update: Chopped up the chassis, got the tranny fitted.
Then I notice that the tranny sit pretty far away from the frame, so I wanted to re-position it, but the bed got into the way. I had to cut out a small piece off the bed, so it will have enough room for the motor to fit.
Next, I cut up the interior floor.
GSR / Atomic
Old 2011.02.07, 10:05 PM   #5
Dr. Kustom
Dr. Kustom's Avatar
After re-position, the tranny is now sit nice and flash with the frame.
Takes up so much interior space.
Now for a mock up with the axles.
GSR / Atomic
Old 2011.02.13, 10:58 PM   #6
Dr. Kustom
Dr. Kustom's Avatar
Update: Now that I've got the tranny fitted, its time to move on to the rear axle. Made a pair of leafs and some shackles, now the rear axle is mounted.
GSR / Atomic
Old 2011.02.15, 10:42 PM   #7
Dr. Kustom
Dr. Kustom's Avatar
Update: Got rid of the low rider style fenders.
Before -
After -
Then got rid of the mold lines left on the body.
GSR / Atomic
Old 2011.02.15, 10:42 PM   #8
Dr. Kustom
Dr. Kustom's Avatar
The stance was a little high from the earlier stage, so I decided to lower it a bit. Had to cut out half of the gas tank to clear the axle.
Then I made some shorter shackles.
Now for the mock up.
GSR / Atomic
Old 2011.02.16, 11:47 PM   #9
Dr. Kustom
Dr. Kustom's Avatar
Update: Toyota center caps!!!
GSR / Atomic
Old 2011.02.20, 09:02 PM   #10
Dr. Kustom
Dr. Kustom's Avatar
Update: Stock steering link take up too much space and I would like something a little more realistic.
Front shackles.
Leafs installed.
GSR / Atomic
Old 2011.02.23, 02:03 PM   #11
mini-z
Administrator
mini-z's Avatar
Thumbs up
How!? I love it!!!
Old 2011.02.24, 12:50 AM   #12
Dr. Kustom
Dr. Kustom's Avatar
Originally Posted by mini-z View Post
How!? I love it!!!
Thanks! The whole center cap are modified from the stock lug nuts, the cap is made out of styrene sheet.
Update: Front leafs attached to axle. Front axle mounted.
Aluminum drive shafts.
Flex shot.
Getting the servo install will be next on the list.
GSR / Atomic
Old 2011.02.24, 01:12 AM   #13
Taking shape quickly as always.
Old 2011.02.27, 11:15 PM   #14
Dr. Kustom
Dr. Kustom's Avatar
Thanks Brian!
Update: Servo installed!
It still have full suspension articulation!
GSR / Atomic
Old 2011.03.03, 05:38 PM   #15
Dr. Kustom
Dr. Kustom's Avatar
Update: trimmed out the servo even more, so I could make the body sit lower. Got the body and rear shocks mounted.
Front body mount.
Rear shocks.
GSR / Atomic
My Chopped Yota MartyJones Mini-Z Overland MV-01 27 2005.04.05 07:01 PM
Finally Finished the YOTA ripper7777777 Mini-Z Overland MV-01 11 2003.09.12 06:58 PM
