Old 2011.04.04, 07:51 PM   #1
Dr. Kustom
Dr. Kustom's Avatar
Send a message via MSN to Dr. Kustom
- Project: Tundra -
As much as I enjoy my LMC, but it's time that I decided to build something that will go faster than 3km/h. So, recently I found this 1/24 scale Toyota Tundra R/C, actually I've seen it for a while now. Ordered one last week and it finally came in the mail today.
The body seems pretty decent.
Here's what I planning to use on this build, a 1/36 Micro-T. Pretty much stock at the moment, other than the 7.4V 180mAh 2-cell Li-Po battery.
Unfortunately, this is not what I was expected...the body is way too narrow...
To be continued...
GSR / Atomic
Dr. Kustom is offline   Reply With Quote
Old 2011.04.04, 08:19 PM   #2
KA2AEV
Mike
KA2AEV's Avatar
So the gauntlet of challenge has been put to The Great Doctor
Lets see what you can do with this Jason!
Team Golddust Racing
Crew Chief of "The Tottenville Terror"
T.G.R. is Sponsored By:
Team Antigua "V26B"
The Caribbean's Premier Contest Station
KA2AEV is offline   Reply With Quote
Old 2011.04.06, 08:00 PM   #3
Dr. Kustom
Dr. Kustom's Avatar
Stay tune!
Update: Got some new parts in and in the progress of widening and extending the body.
- Micro-T chassis set.
- F/R threaded axle set.
- Atomic F/R A.W. rims.
Starting of the body work.
This is how narrow it is compare to my Hilux.
Got some work done.
GSR / Atomic
Old 2011.04.06, 08:01 PM   #4
Dr. Kustom
Dr. Kustom's Avatar
Threaded axles installed.
New wheels.
GSR / Atomic
Old 2011.04.09, 03:20 AM   #5
Dr. Kustom
Dr. Kustom's Avatar
Update: Got some bearings in the mail today!
Also got some more work done on the front end. Laid down more styrene sheets.
Then added some putty.
GSR / Atomic
Old 2011.04.09, 03:21 AM   #6
Dr. Kustom
Dr. Kustom's Avatar
Still need to get to work on the left side and fix that dent on the hood.
Also started to work on the headlight. Made the right side headlight, it will looks more scale compare to the other one.
GSR / Atomic
Old 2011.04.16, 12:40 AM   #7
Dr. Kustom
Dr. Kustom's Avatar
Update: Extended the rear wheel wells.
Did some more sand on the front end.
Applied more putty and fixed the dented hood.
Primed it and more sanding.
GSR / Atomic
Old 2011.05.12, 08:43 PM   #8
Dr. Kustom
Dr. Kustom's Avatar
Update: Sold the Micro-T a while ago, and recently purchased a NIB Micro High Roller. So far got full ball bearings set, threaded axles, both from Losi. Then an unknown rear gear box.
I really don't like AM since I tried out 2.4GHz, so the stock ESC and servo have to go, upgraded to Losi Micro Rock Crawler DSM 2.4GHz ESC with 3 wires servo. I also switch back to the stock rear gear box, IMO it's smoother.
GSR / Atomic
Old 2011.05.13, 04:41 PM   #9
Dr. Kustom
Dr. Kustom's Avatar
Update: Took some Atomic Mini-Z AWD rims and Atomic Micro-T rims, combine them to make my own rims.
Cut the wheel hub off the Micro-T rims and weld it to the Mini-Z rims.
Added a lip to give some aggressive off-set.
A mock up.
3 piece rim.
Add some style to the rim.
GSR / Atomic
Old 2011.05.21, 10:24 PM   #10
Dr. Kustom
Dr. Kustom's Avatar
Update: Vertical front suspension set up on Micro High Roller!
GSR / Atomic
Old 2011.05.21, 10:24 PM   #11
Dr. Kustom
Dr. Kustom's Avatar
Modified front skid plate to sit level with the chassis.
Upgraded to Atomic BB2 motor.
GSR / Atomic
Old 2011.05.22, 04:15 PM   #12
Dr. Kustom
Dr. Kustom's Avatar
Here's a couple flex shots and a short video testing the steering and suspension.
http://www.youtube.com/watch?v=EwvggM7opqE
GSR / Atomic
Old 2011.05.23, 11:03 PM   #13
Dr. Kustom
Dr. Kustom's Avatar
Update: I'll let the pics speak for itself.
GSR / Atomic
Old 2011.05.23, 11:04 PM   #14
Dr. Kustom
Dr. Kustom's Avatar
Front bumper is to show how narrow the body originally was.
That left front fender is not finish yet, still need some more styrene. Here's a mock up on the chassis.
GSR / Atomic
Old 2011.05.25, 03:56 PM   #15
Dr. Kustom
Dr. Kustom's Avatar
Update: New wheels with mock up pics!
Almost line up with the new fender.
GSR / Atomic
new project: front MR03 on F1 pepeuch Mini-Z F1 MF-010, MF-015 8 2012.03.01 04:03 PM
WTB VR Project R/C Unit for AWD and an Mini-z AM module for ko propo Helios EX-10 eztuner12 Mini-Z Marketplace 1 2008.12.23 07:49 PM
RV Project AM 27MHz Micro Fine-Tune Esc Unit (4WD) miniboard eztuner12 Mini-Z AWD MA-010, MA-015 10 2008.10.20 11:34 AM
Unpainted H1 Project arch2b Custom Bodies 19 2005.01.27 09:57 PM
my mini z project dohc Setups 2 2002.11.22 01:12 PM
