Old 2014.04.08, 10:13 AM   #1
steve71075
awd drift car + dnano's
steve turner
berkshire uk
contact me through pm please
hi , i have a few items i'm thinking of selling .
kyosho mini z awd toyota trueno drift car , had this a while and spent a fortune building it and not actually to worried if it sells or not . it started of as an am readyset and have upgraded to .
toyota trueno aero body shell in red , team atlas alloy wheels wide all round with kyosho 11mm drift tyres , 3 racing alloy driveshafts and bearing set , 3 racing alloy steering saver with delrin gear set , 2.4ghz asf board ra-22 , kyosho xspeed motor , kyosho one way front diff , kyosho solid rear axle , kyosho 4,5 degree camber knuckles , alloy tie rods front and rear etc .
all in good used condition , i have had to dremmel the archs slightly for clearance on the wide wheels and the asf board came from japan with a faulty pairing switch so i have removed it and simply bridge the two terminals with a paperclip to pair . also find that the steering is slightly off to the left so you have to trim the controller quite a bit to compensate . had a quick look and looks like there is some wear to the main chassis where the steering arm pin sits so quite a bit of play causing this . a complete main chassis when i did the asf conversion was about 6 from banzai hobby i believe . like i say not to fussed about selling but if someone wants to give me 150 delivered to a uk adress its theirs . can include a perfex kt-18 controller for an extra 35 if needed but i'd much rather keep hold of the controller if possible .
kyosho dnano porsche gt3 in white , kyosho blue alloy rear hubs and alloy front suspension plates 100 + delivery
kyosho dnano lamborghini murcielago in yellow , x-power green alloy rear hubs and carbon front suspension plates 100 + delivery
kyosho dnano ferrari enzo in white , x-power green alloy rear hubs and carbon front suspension plates 100 + delivery
1 x kyosho quick charger + 2 x used once x-power 200 mah lipo batteries with any of the above 25 extra .
all shells have plenty of signs of use , mirrors have come off , scuffs , scrapes etc but the actual chassis are all in good condition .
i do have a limited amount of lightly used hop ups for the dnanos that i could either supply or fit with the above , x-power gyro 20 , kyosho ball diffs 20, kyosho damper plates systems 25 , pn racing rear suspension plate sets 5 , x-power front spring sets 5 , pn racing alloy wheels 15 etc .
i can obviously do you a better deal if you want a few of the tuning parts and i believe i have enough to supply two of the above cars with all of the above parts fitted/supplied .
all items are located in the uk , but can ship worldwide no problem
steve
few pics , i have not had chance to remove the tuning parts from the dnanos yet but for 100 the ball diff , damper system , alloys , gyro etc are coming off
steve71075 is offline   Reply With Quote
Old 2014.04.27, 01:12 PM   #2
steve71075
porsche now on ebay if you fancy a bid and open to sensible offers on the rest .
steve
Old 2014.05.03, 09:18 AM   #3
steve71075
porsche now sold
Old 2014.06.08, 10:07 AM   #4
steve71075
all sold now
do have an enzo dnano either standard or hopped up left to sell
steve
Cheap Drift car 1/28th scale mod wildthing Off-Topic 9 2010.07.20 09:25 AM
AWD Pan Car Body Cherub1m PN Racing 7 2008.11.16 10:00 PM
AWD Pan Car Body Cherub1m Atomic 0 2008.10.11 07:11 PM
FS: Mini-Z AWD w/ extras, NIP AWD Multi-offsets color01 Mini-Z Marketplace 6 2008.05.12 07:54 PM
cute awd drift video herman Videos 6 2006.08.31 11:37 PM
