Old 2008.01.05, 02:58 PM   #1
eztuner12
Do you want to go fasst??
eztuner Kyosho Mini-Z AWD Pro Specs
∑ Chassis:
Kyosho Mini-Z AWD MA-010 Blue/Gray chassis 1.2/8 scale.
PN 98mm wheel base extension kit.
Atomic Titanium screws all around.
Race ready with body shell weight 210g / 7.3/8oz
∑ Suspension:
Front-end.
PN CNC upper front cover.
PN green spring.
GPM CNC front knuckle arm hold 1mm.
Up stop1.6mm.
Down stop 0.4mm
Ground Clearance 2mm.
Rear-end.
Atomic SAS suspension.
Atomic SAS CNC shocks.
Atomic SAS orange spring.
Atomic high viscosity friction grease.
Toe +1 degree.
Camber -2 degree.
Up stop 2mm.
Droop 0.0mm.
Ground clearance 2mm.
∑ Drive Train:
Front and rear Atomic composite adjust differential with delrin 28T gear rear, composite 28T front.
4 Atomic ceramic diff balls p/diff, front and rear in place of 8.
Picco Racing high temp & friction carbon fiber differential grease.
Atomic Diff thrust bearing front and rear diff.
Diff set-up, medium but a bit tighter at rear-end.
Atomic Titanium universal shaft axle.
All around Boca Bearing ceramic.
Kyosho OEM steel drive shaft.
PN CNC center shaft mount set
Atomic 29T composite spur gear.
Atomic treaded front tire 9.5 wide, 23.25mm diameter (trued).
Kyosho MZW30-20 radial rear tires wide, 24.00mm.diameter (trued).
Kyosho MZW2-30 High grip tires front 23.75mm diameter (trued) lees traction & faster lap time.
Kyosho MZW17-20 Wide tires rear 24.30mm diameter (trued), less traction & faster lap time.
Atomic front black split star narrow wheel +2.5 offset.
Atomic rear black split star wide wheel 0. Offset.
Gaui Hurricane 200 Heli M2 locknut for wheel nut.
∑ Steering:
PN CNC front knuckles 2 degree Camber.
PN CNC steering rod 0 degree.
GPM CNC steering assembly Set.
∑ Electronics:
KO PROPO Helios EX-10 Transmitter with Mini-Z module.
Kyosho Mini-Z / KO PROPO e-board with 2x3 stacked 4562 FETís.
Aerogel Powerstor 5V .47F Supercapacitor.
20AWG & 22AWG silicone wiring all around.
Lead Free Silver bearing solder all around.
3Racing CNC lightened battery heat sink.
Homemade lay down crystal adaptor.
Homemade antenna with Futaba antenna wire and silver soldering tip 6in / 152mm length.
∑ Power Plant:
Orion 900mAh H-V AAA batteries.
Atomic CNC motor heat sink with composite vent scoop.
Atomic CNC A2/B2 motor holder.
Maine-iac-Motors-R/C 35T Hand wound armature with big silver com.
PN 35T Armature (2ND Option)
PN 37T armature (Have fun Option)
PN silver brushes.
PN Ultra BB case.
Atomic Neo magnets.
3 PN 104 Cap.
Atomic CNC 19T gear.
∑ Body Shell:
Kyosho Mini-Z Mclaren FI LM white (unpainted, detailed in black).
Kyosho Mini-Z Mclaren FI LM OEM rear win enhanced.
Atomic front CNC body clip.
∑ Observations:
Set-up to be race on RCP track smooth side (On-road)
Only.
∑ Joy Drive Out-come:
Excellent handling and reaction to commands. The GPM CNC steering assembly set works incredible good, it provides a larger window for steering reaction, enriching your possibilities to correct an error or avoid an accident under very high speed
Excellent stability & traction, planted down on straightway & fast and tight corners.
Excellent weight & power balance.
The Orion 900mAh High Volt AAA batty provides a very high jump-start punch, so I had to set-up my Tx TH. Punch & TH. Curve to achieve a perfect smooth but quick acceleration. It is good to know you have all that power on the tips of your finger. Great controllable top end speed.
∑ Comments:
Pics will be post next Saturday 19th right after this season first out-low underground series race.
Old 2008.01.05, 05:52 PM   #2
nunot
Mini-z Noob =D
Very Nice man!
When You fix ur camera please post the photos
I look forward to see them!
The more you search... The less you find...
nunot is offline   Reply With Quote
Old 2008.01.06, 05:37 AM   #3
ruf
4play
ruf's Avatar
Sounds like a nice rig. What track do you race at?
Joe Chen
www.reflexracing.net
Houston, TX
Mini-Z World Champions!
Reflex Racing Blog
Reflex Racing YouTube
Old 2008.01.06, 04:36 PM   #4
eztuner12
I am a retired 1/10 and 1/8 fuel Pro driver, I raced all around the world for about 35 years as team driver for a few top notch brand as Delta, BMT and Serpent, but still go to a few tracks around for fun race and exhibition races.
Actually I have 3 RCP mini-96 tracks and 3 expansion kits plus extra parts as; chicane, 45 degree, etc. Occasionally a few 1 1/0, 1/8 fuel and 1/5 gasoline scales racers partners get together and race our own race series, we lake to call it underground racing and only invited racers can participate, we go by ROAR, IFMAR race rules but regarding modification to the chassis and motor, there is no rule, as well as, we race pan, 2wd and awd together and we race on-road only.
File Type: jpg team bmt & team serpent top drivers.jpg (129.1 KB, 203 views)
Old 2008.01.06, 09:05 PM   #5
CristianTabush
CristianTabush's Avatar
Hi Richard! Haven't heard from you in a while...
Cristian Tabush
REFLEX RACING USA
http://www.reflexracing net
Old 2008.01.06, 10:54 PM   #6
eztuner12
Hi Cristian,
Yes I have been learning to fly R/C electric helicopter for the last 5-months, donít know if you have had any experience with helis, but let me tell you it has been a thrill. Now that I learned the basic acrobats and going into advance-inverted acrobats, I am taking it more calmly and investing lees practice time so I can start again with R/C cars.
It has been great hearing from you and please forward my best regards to Rob and all the Atomicmods force team as well.
Regards,
Richard
Old 2008.01.07, 01:15 AM   #7
∑ Comments:
Pics will be post as soon I learn whatís going on with my camera.
we'll be waiting...
Old 2008.02.07, 09:57 PM   #8
eztuner12
Here are the pics
Hope you all Like it, I do!
Old 2008.02.08, 03:16 AM   #9
RobinZ
RobinZ's Avatar
Very nice! Thanks for sharing the pics.
I see a special bar located at your extension kit, probably to stabilize the pretty long 98mm rear end? Is it hand made? What material is it?
I've expereinced some rear end flex problems with 98mm extension in combination with SAS.
Off topic but nice: Concerning helis and thrill, have you ever seen this:
http://nl.youtube.com/watch?v=q6F-0rIpLJE
Local RC shop heli specialists say it is real.
MA-010 ASF, MR-02 98mm ASF, MR02 94 rm AM, OL
My Gallery
RobinZ is offline   Reply With Quote
Old 2008.02.08, 10:38 AM   #10
eztuner12
Hi Robinz
Yes, the rear brace you refer to, is to stiffen the rear end to achieve a more responsive suspension effect, it is hand made, I used a 2mm thick portion of carbon fiber.
Regarding the Heli video, man that’s my goal. This R/C helis is turning me mad since I started with R/C electric helis, about 6 month a go I only eat slip and 3Dcertainly never let down the R/C on-road cars
At this very moment Iam in Guatemala (Central America) at a heli International competition at Iguana Club, These babies’s would do any thing on the air if you have the hart and guts of course, as well as, the now how!
Thx 4 ur comment.
Richard
BTW:I love your country The NL, Specially the food, it is just spectacular!!!
Old 2008.02.08, 05:44 PM   #11
RobinZ
RobinZ's Avatar
thanx man!!
and thx for the tyres tip.
My Gallery
Old 2009.12.05, 10:39 AM   #12
Breakneck
Where can i get a set of the Boca full ceramic bearing for awd?
Breakneck is offline   Reply With Quote
Old 2009.12.05, 10:43 PM   #13
MINI-D
Registered User..Of What?
MINI-D's Avatar
Breakneck, do a Google search for: "Boca Bearings"
thay ship to your door.
MINI-D is offline   Reply With Quote
Old 2009.12.07, 02:39 AM   #14
dang... can't believe i missed the pics for so long... just saw them...
lovin it... thanks for sharing...
Old 2010.04.06, 10:31 AM   #15
AeroFinn
∑ Chassis:
∑ Suspension:
Front-end.
PN green spring.
Up stop1.6mm.
Down stop 0.4mm
Rear-end.
Toe +1 degree.
Camber -2 degree.
Up stop 2mm.
Droop 0.0mm.
∑ Drive Train:
∑ Steering:
∑ Electronics:
∑ Power Plant:
PN silver brushes.
PN Ultra BB case.
Atomic Neo magnets.
3 PN 104 Cap.
∑ Body Shell:
∑ Observations:
Only.
∑ Comments:
Hi Richard,
Impressive rig you have..
As I am working on the steering of my AWD I am insterested to hear more about this "GPM CNC steering assembly set" -> I did some googling but couldn't find much info on it. How does it differ from other aluminum / stock plastic servo saver assemblies?
I hope you don't bother my question, thank you again for all great contribution to this forum!
AeroFinn is offline   Reply With Quote
FS: Kyosho Mini Z AWD with tons of upgrades $135 atallfunguy Mini-Z Marketplace 0 2008.09.17 11:27 AM
New to AWD: Kyosho kit with bearings?? Yeap Mini-Z AWD MA-010, MA-015 5 2007.10.05 10:32 PM
1st annual kyosho mini z nationals crashholly Events 35 2003.06.23 12:39 PM
