• Chassis - Any manufacturer, mass market/production chassis compatible with Kyosho 86mm autoscale permitted.
• Motor - Any Manufacturer motor permitted.
• PCB - Any modification permitted.
• Bodies - 86mm Autoscale required, finished autoscale or unpainted white body. Minor Modification (shaving or drilling, adding wings etc) permitted for performance gain.
• Wheels - Any Manufacturer wheels.
• Tires - Any Manufacturer brand rubber tire (No grooving, cutting or silicone based tires allowed)
• Batteries - Four AAA batteries. Alkaline, Ni-MH or Ni-Cd batteries may be used. No other type of battery may be used. For example: Lithium Polymer may not be used, Ni-Zn may not be used.
• Ball Bearings - Any manufacturer non ceramic ball bearings are permitted.
• Front Suspension - Any manufacturer suspension and parts permitted.
• Rear Suspension - Any manufacturer suspension permitted.
• H/T Plate - Any Manufacturer H/T plate permitted, must be appropriate to stock wheelbase for chassis configuration and Autoscale selection.
• Wheel Nuts - Any Manufacturer wheel nuts permitted.
Modifications to the rules
• Oils, lubes, greases, tire tape will be allowed in our series.
• Autoscale modifications must not alter the stock autoscale form and envelope dimensions. Example, Chopping the top to reduce overall autoscale height not permitted.
Schedule:
86mm and 90mm will run parallel with HFAY season. January thru December will be mixed 86mm and 90mm classes.
