Old 2013.12.20, 08:41 AM   #1
What's Trending
Thought it would be interesting to see what is trending in setups for specific classes these days given the normal swing back and forth with various manufacturers and or technologies.
Old 2013.12.21, 12:30 AM   #2
DMALMAD
DMALMAD's Avatar
At Majs Hobby shop we all run the pn dbl a-arm with pn v4 pod with mostly r8 bodies.
Old 2013.12.21, 04:07 AM   #3
Rune
Mini-Z Norway
Rune's Avatar
Over here it's mostly LeviTeZer and double A front ends.
Rear ends are mostly a mix and match from all the manufacturers.
Mini-Z Norway
Old 2013.12.21, 06:11 AM   #4
NoBrainer
NoBrainer's Avatar
Isn't it also mostly DPS in stock and tri-damper in GT Mod?
Old 2013.12.21, 10:54 AM   #5
DMALMAD
DMALMAD's Avatar
dps for everything in NJ
Old 2013.12.21, 05:51 PM   #6
lfisminiz
lfisminiz's Avatar
Arch...we run mostly 70T on our HFAY sized track. I think most are running Aarm. Im running Aarm and been messing with the Levitezer front also. Mostly normal DPS. I have some with tri-shock to.
Old 2013.12.22, 08:23 AM   #7
Mike Keely
The guys that are running the double A arm front ends, are you running the +1 lower arms?
DG-Designs / Brooklyn Hobbies
Old 2013.12.22, 09:37 AM   #8
chad508
chad508's Avatar
Double a arm and tri shock on all my cars regardless of class.
PN Racing
R1Wurks
LET's Go Racing
DG Designs
Old 2013.12.22, 06:53 PM   #9
briankstan
briankstan's Avatar
I'm running the a-arm, standard lowers, Damper with dual shock, and the reconfigurable mount.
Old 2013.12.22, 08:10 PM   #10
DMALMAD
DMALMAD's Avatar
Running the standard lower arm on aarm
Old 2013.12.23, 01:32 AM   #11
unearthed name
PN doubler a arm and PN motor pod with either reflex or PN TDS here in indonesia.
bodies are either R8, 458 GT2, or HSV.
Old 2013.12.23, 10:54 AM   #12
phea
Dexterous
phea's Avatar
Send a message via AIM to phea
Many of the local racers run the standard front end setup and DPS rear. Curious to try the LeviTeZer setup that Rune mentioned.
Stephen Bui
phea is offline   Reply With Quote
Old 2013.12.25, 06:44 PM   #13
TheRinger
THATS HOW I ROLL
TheRinger's Avatar
A wide variety of stuff.
Awesome RC Racing R.I.P
