Old 2018.03.18, 04:23 PM   #16
Zeromerk89
Thanks either way. I really appreciate the help. Might be one of those things that just isn't meant to be. He may be purchasing one of the new RWD models.
Zeromerk89 is offline   Reply With Quote
Old 2018.03.19, 01:15 AM   #17
from its looks, the kt18 kinda looks blah... however it is an underrated radio...
i'm pretty sure that you can set the steering endpoints...
if i remember correctly, for more steering to the right... turn steering wheel to the right, then press the right trim until you reach the desired right end point...
do the same for the left... turn steering wheel to the left, then press left trim until you reach the desired left end point... hope this helps...
there's a link in my signature to kyosho manuals... check the one for the kt18... good luck...
Old 2018.03.19, 01:17 AM   #18
uh i just realized it's the sport version thus using the kt-19...
Old 2018.03.19, 10:39 AM   #19
Zeromerk89
Yep. Ditched it. Guy is buying an MR-03. Gave him a little cash towards it for this 02 chassis. I'll get an ASF PCB for it another time.
Old 2021.11.11, 01:08 PM   #20
Old Crow
Old Crow Racing
Old Crow's Avatar
Can I put a MR-03 EVO board in an MR-02 if I just switch the servo motor?
Thank you
Old Crow is offline   Reply With Quote
Old 2021.11.11, 05:55 PM   #21
Thank you
Maybe, but you would have to do some dremelling and reconfiguring of the top cover. There is a DasMikro ASF board that is much more of a direct replacement.
Old 2021.11.12, 04:24 AM   #22
Old Crow
Old Crow Racing
Old Crow's Avatar
I figured the cover would need adjustment, if not all out removal.
I want to change so I can use a different protocol. Too many different transmitters, want to unify. Brushless would be nice also.
Old 2021.11.12, 10:12 AM   #23
The only thing about the EVO board is I'm not certain how much it depends on a tight-fitting top cover to hold the receiver in place. I mean, it snaps in, but it's sometimes not the most secure connection. You can probably get it to work, with a custom cover.
FS: MR02 (With MR01 PCB) Draconious Mini-Z Marketplace 17 2009.09.05 06:13 PM
mr02 pcb board dohc Mini-Z Marketplace 6 2007.10.23 08:39 PM
MR02 PCB into a F1 revzalot Mini-Z F1 MF-010, MF-015 15 2006.10.31 05:25 PM
Wtb Mr02 Pcb SuperFly Miscellaneous Discussion 2 2006.05.30 08:44 PM
MR-01 PCB on a replacement MR02 chassis Cian@work Parts and Hop-ups 26 2003.10.04 07:40 AM
