Old 2017.04.10, 11:20 AM   #61
Kevinmueller
Bavarian Bullet
The metal parts for the front suspension are now up on the MC3 website. Once the springs arrive their will be an entire front end kit that you can purchase as well. We test fitted the parts and after a small amount of sanding and some grease they worked very well. The upper suspension hinge pin is now threaded (like the MR-03 hinge pin) and is screwed into the upper suspension arm. When you use the hinge pin along with the metal adjustment sleeve all of the play in the upper suspension is now removed. The adjustment sleeve is a bit of a tight fit into the upper servo cover but it's significantly better than the 3D printed one. The thread on the King Pin is a bit sharp and catches the inside of the upper suspension ball. I simply used 1000 grit sand paper and went around the treaded part a couple of times then applied some silicon grease and this took out any binding between the two thread and the suspension ball. With all the parts installed in the car you definitely notice that the front end is much more accurate and points where you want it to. Hopefully guys who could not complete their build will be able to now and get to enjoy the car as much as we do.
Kevinmueller is offline   Reply With Quote
Old 2017.04.10, 01:16 PM   #62
Sinister_Y
Sinister_Y's Avatar
Pic of the front end kit
Mini-Car Club of Canada (MC3)
www minicarclubofcanada com
Old 2017.09.01, 02:33 PM   #63
durtbag
durtbag's Avatar
this needs to happen
Originally Posted by Sinister_Y View Post
We will start work shortly on a KMD-FR01 version that will accept a sealed servo, rx and esc like GL's GLA setup. This should also work for those that aren't into Mini-Z and are coming from 1/10th and don't have old F1's lying around waiting to be transformed into a fast, fun, racing machine.
Im totally one of these guys. I looked into building from scratch and got mind boggled. I have a few of the Atomic line of chassis and a track in the garage just waiting for some F1 action. Im also trying to get 1/28th going in BC. An F1 option would be awesome.
Terry
durtbag is offline   Reply With Quote
Old 2017.09.01, 09:26 PM   #64
(warning off topic post) nice track...
MP V4: new chassis ivanmartin18 Aftermarket Chassis 70 2016.02.02 12:00 PM
shop.tinyrc.com: The 2011 F1 Season Opener Sale, Chassis Sale, More AutoScale Price R Mrs Mini-Z Newsletters 0 2011.03.16 03:21 PM
MR03 chassis: Overall better than 02 main chassis? Felix2010 Mini-Z Racer MR-03, MR-03 VE, Sports Series, EVO 29 2011.02.20 03:44 PM
FS: a variety of Mini-Z chassis' cowboysir Mini-Z Marketplace 22 2008.06.02 07:40 PM
Iwaver alloy+carbon fiber chassis marc Parts and Hop-ups 4 2006.06.07 10:57 AM
