Old 2021.09.01, 05:58 AM   #1
unclearty
What's better....mah or voltage?
I've bought a new analyzing charger...begun going thru AAA batteries for upcoming racing season. If I'm running stock..brushed motor...which is more important...MAH or voltage?
unclearty is offline   Reply With Quote
Old 2021.09.02, 05:46 AM   #2
SuperFly
bitPimp
SuperFly's Avatar
internal resistance
mini-z gallery
PDX Mini-Z
Old 2021.09.02, 06:48 AM   #3
unclearty
what would be considered GOOD for a AAA battery?
Old 2021.09.02, 11:39 PM   #4
SuperFly
bitPimp
SuperFly's Avatar
New AAA NiMH usually have an internal resistance <100mO. When mine hit about 350-400, I use them for my controller.
To better answer your question, and probably tell you something you already know, but mAh = how long they will last, and voltage will give you torque and top end. Internal resistance has to do with how efficiently they can dump out their power. To the best of my knowledge. MAh can also indicate how "hot" a battery will be. 750mah cells are often very fast up front, and have a noticeable fade over their span, where 900-1000 mah cells don't seem as punchy at the start, but maintain a more even level of output, and usually for a longer span.
mini-z gallery
PDX Mini-Z
Old 2021.09.07, 07:05 AM   #5
unclearty
Thanks for your help!
M.H.S. Racing Discussion HobbyShopOwner Mini Z Racing, Maj's Hobby Shop, Saddle Brook NJ 9983 2016.07.02 02:25 AM
Ideal Dynamometer Test Voltage Jshwaa Motor Tech 11 2015.12.22 04:04 PM
Lower mAh than advertised. RFick73 Batteries, Chargers and Dischargers 15 2014.03.31 09:50 AM
Capacitor Voltage question - EE help ProfoxCG Mini-Z Science 17 2009.03.05 09:44 AM
NiMH Battery Info G-Class Parts and Hop-ups 5 2004.09.09 11:29 AM
