Old 2019.04.20, 07:50 AM   #16
I thought it had to be windows OS as well, thus the surprise when someone told me this tablet worked.
Old 2019.07.03, 07:24 AM   #17
Traveler
of both Time and Space
Traveler's Avatar
Just built my first EVO car from parts, and want to run it with brushed motor, but only have the PN Bluetooth ICS programmer. What hardware do I need to be able to change the setting from brushed to brushless? And are there any alternatives to the Kyosho cable?
Traveler is offline   Reply With Quote
Old 2019.07.03, 07:31 AM   #18
I am not aware of any alternatives as of yet, if there are, someone please let us know.
You need to go to ICS settings to change to brushed. On my cars, it was set to brushless by default.
Old 2019.07.03, 06:08 PM   #19
Traveler
Traveler's Avatar
Thanks for the response. Thatís disappointing though. Guess Iíll have to wait to finish the build and test after I find someone with a Kyosho ICS cable. Iím not shelling out $55 for one after spending over $100 for an EVO board and receiver.
Old 2019.07.05, 06:40 PM   #20
Traveler
Traveler's Avatar
DasMikro makes a USB cable that works with the EVO. Retails for $22 if anyone is looking for a cheaper alternative to the Kyosho cable.
Old 2019.07.06, 11:26 AM   #21
This one?
DasMikro bluetooth ICS Adapter For Kyosho Mini-Z
The listing does not mention compatibility with EVO nor do the corresponding apps.
Old 2019.07.06, 01:57 PM   #22
Traveler
Traveler's Avatar
No! Itís not Bluetooth. Search eBay for DasMikro ICS USB Adaptor HS for EVO.
Old 2019.07.06, 02:33 PM   #23
thanks, very good to know they have a new one out. Odd that it's not on bangood yet and just excel.
Anyway, they link to the Kyosho software and EVO supported by USB connection only it seems. I had already bought the Kyosho version, not much more expensive BTW from JDM. Otherwise, would jump on this myself.
Old 2019.07.06, 03:18 PM   #24
Traveler
Traveler's Avatar
I got the KO Propo version from AMain for $37 before someone told me about the DasMikro version.
Old 2019.07.07, 07:11 PM   #25
Traveler
Traveler's Avatar
I need help. I got the adapter, downloaded and installed the driver from KO website and ICS software from Kyosho website. I can see the adapter on Com5 and select it in the software, but when I try to read or write to the board, I get a communication error. I donít know what Iím doing wrong. Any help is appreciated.
Old 2019.07.07, 10:07 PM   #26
Traveler
Traveler's Avatar
Got it working!
Old 2019.07.08, 06:23 AM   #27
What was the solution?
Old 2019.07.08, 06:28 AM   #28
Traveler
Traveler's Avatar
Not sure how/why, but when I used the black/white only extension cable, it worked! The short Mini-Z cable with red/white/black that I used initially never worked alone. Makes no sense, but glad I got it working. Bone stock EVO car feels pretty good!
Old 2019.10.05, 12:14 PM   #29
Originally Posted by arch2b View Post
No, bluetooth does not work with EVO yet. Thus my inquiry about cheap Fire HD tablet working with the Kyosho ICS software. Would need a micro-b adapter for the USB port as well.
Sorry for my misleading answer, I thought the question was more generally whether the Kindle could run the various ICS mini-z apps, not the EVO specifically. I know, thread title.
I did end up getting the dasmikro cable, but I can't get it to work. Is there a driver that needs to be installed in addition to running the app? I'm not a Windows guy, but I think my problem is identifying the device and assigning it to a COM port. When I run the app, it will say it's reading the settings but just hangs and kind of locks up. ugh. Windows 8.1. Pretty sure it's that I need to install that KO driver, but can't seem to make that happen.
My EVO combined with an EX6R has seemingly zero deadband between forward and reverse, and no brake in between. Like letting off the throttle sometimes sends the car into reverse.
edit: as a mac user, let me put this here for future bumblers like myself. You have to use Device Manager to manually install the Ko Propo drivers. You have to make sure the cable is plugged in correctly, and you have to turn the car on in pairing mode while plugged in.
Old 2020.02.13, 06:41 AM   #30
r46
r46's Avatar
Having issue reading board
Drivers manually installed (win7)
Com port assigned in app
Using 2 wire extension & batts in chassis
Holding pair button or not same result..
https://ibb.co/6NMfZ9j
https://ibb.co/FBrcDq6
http://i810.photobucket com/albums/zz24/triks75/Wlmr-blue-sm jpg
Dnano
#911 #Enzo #Lambo
Motoracer x2
02ex Hfay
02mod
03 Hfay
03 mod
03VE
F1ve
020 50t
030evo
AMZ
GL racing Rider
TZ4
reserved for
r46 is offline   Reply With Quote
Forum is not found on taptalk app. referjohn Site Feedback 0 2014.11.28 10:20 AM
X-Mod Evo Car, Nissan Skyline GTR on start, Evo on end! (Project) targetingxmod Xmods Evolution 17 2012.08.23 03:26 PM
Mini-Z Electronic Board Transplant to Xmods Evo. eztuner12 Transmitters, Receivers and Crystals 1 2007.06.12 02:10 PM
MA-010 vs. XMOD EVO Br0ken Autumn Mini-Z AWD MA-010, MA-015 14 2005.12.31 09:22 AM
Newbie Review of Mini-Z vs XMOD vs XMOD EVO bemoore Beginner Questions 6 2005.12.14 02:48 PM
