Old 2015.07.02, 07:03 PM   #1
jcs_tuesday
Cool Ball Differential
Just Add Space Inside Outer Hub For The Shim Plate, Make Each Plate Different Thickness. You Can Do This To The HPI Racing Micro RS4.
jcs_tuesday is offline   Reply With Quote
Old 2015.07.03, 07:43 AM   #2
doug01n
doug01n's Avatar
Sorry... didn't understand, but curious about this. Can you post a picture of it?
Old 2015.07.06, 03:07 PM   #3
jcs_tuesday
I Can Not, If You Aquire, A Micro RS4 Ball Differential, It Is All This All Design.
Just Remove Some Spacing Inside Hub To Add Plate At Thickness That Are Different To Solid Lock Nut To Level.
Old 2015.07.07, 06:29 AM   #4
? I don't follow. It's clear English translation is not entirely proficient but context helps to some degree.
Old 2015.07.07, 06:31 PM   #5
jcs_tuesday
The HPI Racing Micro RS4 Ball Differential Can Be Scale To The Mini-Z MR Chassis.
To Tight The Ball Differential You Lock The Lock Nut Tighter. If you design in CAD a PLate The Differential Can Only Become So Tight. With Different Layer Thickness Of Plate You Can Simple Change Plate And Lock Differential For Easy Ajustment As The Word Ajustment????
Old 2015.07.07, 08:21 PM   #6
DMALMAD
DMALMAD's Avatar
I think the question I have is why? you haven't really provided any useful information just left a bunch of question marks
Old 2015.07.07, 09:42 PM   #7
cowboysir
The word is adjustment.....easy as that?
my custom body album...
Old 2015.07.08, 04:57 PM   #8
jcs_tuesday
Tuning.
If I Can Make The Plate As 11 Plate, That Is 10% Each Plate Toward Stiff And Neutral. A Race Sheet Can Show Plate On Differential, Plate 5 as 50% Tight.
Every Chance You Run Your Car You Will Know It Is 50% With Others.
The way we have it is backward and slower to understand as a group.
Tuning With The Ball Differential shuter Mini-Z Racer MR-02 3 2007.01.22 01:50 AM
Kyosho Ball Differential faydoiinspire Mini-Z Racer MR-02 4 2006.02.01 06:00 PM
GPM ball differential stuZ Mini-Z Overland MV-01 6 2003.08.07 04:36 PM
ball differential help baseline Parts and Hop-ups 7 2002.09.08 05:31 PM
unnamed ball diff setup with bearings bendalf Setups 4 2002.07.22 05:46 AM
