Old 2008.07.23, 05:49 PM   #16
hipsterdufus
what KV losi system did you put in your boat
i assume the highest rpm 10kv
i got a 8750 sitting around
hipsterdufus is offline   Reply With Quote
Old 2008.07.24, 12:15 AM   #17
Nic-Z
Nic-Z's Avatar
Send a message via MSN to Nic-Z Send a message via Skype™ to Nic-Z
its the 8kv one, I have the 104kv er whatever the number is in my micro-t, however I am debating building another one with a 11.1v lipo and a 30a brushless esc and a 4kv brushless motor around the same size, I would just put the 11.1v on the one I have right now but I don't know if the losi system could take 11.1v?
1....ok maybe 2 of each.
Nic-Z is offline   Reply With Quote
Old 2008.07.24, 08:30 AM   #18
hipsterdufus
sweet, i still havent used my lambo boat, but my friend just closed on a new house with a big indoor pool, cant wait to see it run
ill check out your pictures and try to install this 8kv in this weekend
thx!
Old 2008.08.24, 08:42 PM   #19
mk2kompressor
at the Bleeding Edge
mk2kompressor's Avatar
hey nic,you got any parts left for the f1 style boat?
im after the shaft and outboard
Team B.E.R.T
MR02/3 eating MA010
MR-03
HFAY S9 F1 Winner
Sinister V1
MRCG Prototype
MRCG 1.0
Bleeding Edge Racing UK
Old 2008.08.28, 01:26 PM   #20
Nic-Z
Nic-Z's Avatar
yeah no luck there, I know theres one up on the bay right now but it would probably be too dear to pay just for parts.
Old 2008.08.28, 02:02 PM   #21
mk2kompressor
damn,ill keep looking
Team B.E.R.T
MR02/3 eating MA010
MR-03
HFAY S9 F1 Winner
Sinister V1
MRCG Prototype
MRCG 1.0
Old 2008.09.09, 01:33 PM   #22
Netz135
Netz135's Avatar
09/09/08
It's been awhile since the last post here - but I needed a lower Unit for 1 of my boats - and called California ... told them I didn't need the whole motor - and they work'd with me and got me just the lower unit part!!!
Also - here's another "prop trick"
If the prop U wanna run drags your boat speed down ... try sticking a tooth pic in it - chuck it up in a drill and as U spin it - take a fine file and dress the DIAMETER down. A rule of thinb is - adjust speed with PITCH - and motor RPM'S with Diameter.
I reduced a 2 blade 15mm Dia - 1.0 pitch to ... 13mm Dia and it made a BIG Difference in motor RPM's and increased speed .....
Of course remember to sharpen the blade edge with fine sandpaper when your done .....
Netz135 is offline   Reply With Quote
Old 2008.09.11, 11:38 AM   #23
Nic-Z
Nic-Z's Avatar
soo if I sent you my prop would you do that for me for a small fee?
Old 2008.09.12, 07:03 AM   #24
Netz135
Netz135's Avatar
Sure Nic ... U have my address I think ... It's a easy mod though
Old 2010.09.16, 06:56 AM   #25
papaya
Any cheap & effective way to improve the running time? 5 minutes is too short for 1 charge.
Also care to recommend the parts to purchase?
papaya is offline   Reply With Quote
wtt mini z f1 for rc boat lioniz Mini-Z Marketplace 12 2008.08.09 04:22 PM
Mini Z Formula Boat review Yeap Miscellaneous Discussion 0 2005.06.09 11:57 AM
