Go Back   Mini-ZRacer.com Forums > Mini-Z Marketplace
Old 2011.06.20, 11:32 AM   #1
Roger
Roger's Avatar
PN Dual Charger system with stand and power supply
Contact: XX
Description: Dual PN S6 NiMH/NiCd/LiPo/LiFe Multi Balance Chargers with power supply.
Price: SOLD
I have a 2 PN Chargers with a Novak power supply for sale. I've used these chargers only for mini-z AAA batteries, but you can also use these chargers for other applications. Detail desciption is listed below:
S6 Multi Balance Charger Operating voltage DC 11~18 volts Idling current approx. 100mA Charge/discharge power max. 80/8W NiCd/MH 1~15 cells LiIo/LiPo/LiFe 1~6 series Pb 2~20V Charge current 0.1 to 5.0A Discharge current 0.1 to 1.0A No. of cycle 1 to 5 times Battery data memory up to 5 data Computer USB port Temperature sensor port
Lithium battery voltage type LiIo:3.6V, LiPo:3.7V, LiFe:3.3V
NiCd Delta-peak voltage sensitivity 5 to 20mV
NiMH Delta-peak voltage sensitivity 5 to 20mV
Battery temperature cut-off 20 to 80C or OFF
Waste time between charge/discharge 1 to 60 min.
Trickle charge mode ON/OFF, up to 200mA
Integral timer limit for safety 10 to 720 min.or OFF
Maximum charging capacity limit for safety 10 to 9990mAh or OFF
Key beep and buzzer sound ON/OFF
Input power low alert 10 to 11V
- Operating software Every operating program in the unit is controlled with mutual links and communications to prevent every possible error, so it introduces the maximum safety, such as input voltage warning, reverse polarity protection and Lithium cell-count input error warning.
- Individual voltage balancer for Lithium batteries S6 Charger has an individual cell voltage balancer inside. So it does not need any balancer separately when charging Lithium batteries (LiIo/LiPo/LiFe) for voltage balancing.
- Accept various types of Lithium battery S6 Charger can accept three types of Lithium batteries - LiIo, LiPo and LiFe. They have different characteristics by their chemistry. You can select any one of them that you are going to process before the job. For their specifications, refer 'Warnings and safety notes' section.
Reason why im selling them is because im getting out of mini-z at the moment. I don't have the energy and time for it now. Everything you see in the photo is what you'll receive. Currently, it's set up for mini-z charging with a Novak power supply. You can also use a more powerful power supply by just unplugging the Novak mini-power supply for mini-z charging and pluggin a larger higher amp power supply.
If interested, please contact me at the e-mail provided above. Thanks for looking.
~ Roger Serafin
Last edited by Roger; 2011.06.27 at 12:16 PM. Reason: ITEMS SOLD. Thankyou MiniZracer.com :)
Roger is offline   Reply With Quote
Old 2011.06.20, 02:12 PM   #2
Roger
Roger's Avatar
Will also include 2 atomic battery holders for charging into the package.
Old 2011.06.24, 06:19 PM   #3
Roger
Roger's Avatar
Still available.
Old 2011.06.27, 11:48 AM   #4
Roger
Roger's Avatar
sale pending........
Old 2011.06.27, 12:15 PM   #5
Roger
Roger's Avatar
Charger system SOLD.
